Results 1 to 10 of 24
September 26th, 2007 11:30 AM #1
just wanna ask is there any way or modifications i can make sa engine or any other parts ko to save gas?
im only getting 8.5 km/l , only 20% of it ang stop and go lahat highway, ako lang sakay ng auto walang heavy loads, 40% lang and a/c use sa bawat trip, slight open windows lang pag 'di naka a/c. pag pwde salida neutral mode nalang.
btw engine is 4g92 lancer glxi '97 w/ 120k+ sa mileage
September 26th, 2007 12:31 PM #2
joke lang po pero totoo:
1.lagyan mo ng kalso gas pedal mo. (para hanggang 2000rpm lang lagi makina mo!)
2.palitan mo ng ibang kotse (spark, alto, or yung mga kie-van tulad ng supercarry/atrai na matic)
eto seryoso:
1. pa-tono mo makina mo
2. palitan mo all 6-8 liters of your ATF! including the filter inside
3. palitan mo ng MT
September 26th, 2007 12:53 PM #3
Basing from the description of your car I'd say that there's very little here you can do
A Lancer glxi '97 at 120k mileage is rather old. Maybe you can give it a good tune-up. Automatics always consume more than stick shifts even if they are brand new, how much more for an old one?
If you can sell it and get a smaller displacement second hand, manual type then I think you can be better off.
September 26th, 2007 01:47 PM #5
September 26th, 2007 01:55 PM #6
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 26th, 2007 03:34 PM #7I think the thread starter is from Batangas and there are no lpg stations there.
September 26th, 2007 03:39 PM #8
dont step on the gas too much, maintain a sensible rpm rate so fuel consumption be regulated to optimum
Zombie
- Aug 2006
- 728
September 26th, 2007 04:56 PM #9i think 8.5/L is good enough (except if all you do is highway driving. para kang galant niyan).
replace ATF first
tune up, and adjust valve clearance
maintain correct tire pressure
September 26th, 2007 05:11 PM #10
Ask ko lang naka by pass na ba Yan or servo pa din ang gamet mo
4g15 rare Idle motor (servo)
