Results 1 to 8 of 8
    guys ask ko lang sign na ba ito ng sliding clutch kasi kahit segunda palang pag medyo pataas yung kalsada hindi naman matarik pero biglang bumabagal so ginagawa ko eh medyo tatapak sa clutch para kumapit yung acceleration, ano ba dapat palitan?........clutch disk, pressure plate at flywheel? yung flywheel ko kaya okay pa kasi sabi ng dad ko nung 2001 pinareface/pinarephase(di ko alam spelling eh) yung flywheel from 2001 wala pang pinapalitan sa clutch....
    Oct 2007
    sir,hirap po ba humatak yan?di ako nagkakamali clutch na po mismo yan...palitan muna yung clutch disk, pressure plate at yung isa forgot ko na...basta tatlo po yun...kung may budget ka pa, sabay muna tune up, change oil/oil filter and fuel filter at air filter.tiyak po sir lalakas po ulit car mo..
    uu sir tama mahina humatak....kaka change oil ko lang at kakapalit ng oil filter, kaso hindi pa ako nag papalit ng air filter.
    Jan 2008
    EGcolmhan.. nangyari na sa kanya to hehehe.. clucth ang problema nya..
    Aug 2003
    Quote Originally Posted by EGcoolmhan View Post
    clutch disk, pressure plate, and release bearing if i'm not mistaken.
    Nov 2007
    Quote Originally Posted by roninblade View Post
    Tama yun sabi ni roninblade...palitan itong tatlo...yun flywheel mo dapat pinalitan na lang siya and don't go for refaceing....hindi maganda ang performance ng transmission
    Kelangan ba talaga palitan pati flywheel? From what I know kung slippery and clutch lining normally clutch lining lang talaga pinapalitan. The pressure plate needs only to be replace kung yung, what you call that (spokes?) ay hindi na pantay. And if you replace the pressure plate might as well replace the release bearing. Unless you have the bread of course you can change all fours.
    If your vehicle is a normal driven car hindi pang karera, i think your flywheel is okey.
    Nov 2003
    kung 7-8 years na since ginalaw nyo yung clutch or since inayos sya then it might be about time to fix it again.
mabagal pag medyo pataas ang car ko....help ...clutch problem kaya
