Results 11 to 18 of 18
- May 2011
- 50
May 19th, 2011 06:15 PM #11lol!
i agree. sa casa kasi ilalagay nila is yun according to their standards. kaya minsan mas maganda parin magpaservice sa casa kasi nasusunod yun protocol ng service.
dati naman with our other car, i had a problem with the response on R. as in minsan ayaw kumagat ng gear. then dinala namin sa casa, naubos na pala yun "lifetime supply of smg fluid"
May 19th, 2011 06:38 PM #12
baka nga bro... abnoy dad ko eh... wahahaha...
dati kasi, ayaw ng kumagat na umandar pag naka D.... eh siunce newbie ako sa cars, di ko alam sira... 1 year na sa akin ung kotse... tapos nung pinatingin ko, nakita nila ung ATF eh super dumi daw... as in brown mud na ung kulay... hehehe... so binuksan nila tapos nakita nila sa filter na buo buo na ung nakalagay... after palitan, ayun umandar na ng maayos for a month tapos humihina na naman hatak ngayon... ayun... kaya nag helpline na ako sa inyo... wahahaha!!! siguro nga hindi maayos ung ATF na binili ng dad ko... thanks sa mga inputs...
- Dec 2009
- 21
May 24th, 2011 01:59 PM #13Hi to all,
Need help din po.. My car have same problems.. delay response pg cold start.. at eto pa..pag shift ko sa R ok naman response nya pero lakas vibration. Btw, 93 corolla un car ko. I replaced atf last October 2010. Ok pa naman level at color nya. What could possibly is the problem? Newly replaced din nga pla all engine and transmission supports. TIA.
- Jun 2010
- 258
May 26th, 2011 05:26 PM #14kung toyota AT car nyo used Toyota ATF Type T-IV
kung honda AT car nyo used Honda ATF Z1
kung resing resing kayo RP Fully Syn. on engine at RP Max ATF on AT tranny
May 30th, 2011 03:16 PM #15
bumili ako ng Top 1 na ATF last week (Dexron III)... i'll try to have my ATF replaced tomorrow and will let you guys know kung anong results... according kasi sa Manual nung kotse, Dexron III ung need hanapin so binili ko ung pinaka ok sa Handyman na ATF... my bad nga kasi di ko pa alam si Royal Purple ATF nun eh...
pero yun nga, I'll let you guys know kung ok sya...
by the way Chawap, we have the same problem...
- Jan 2010
- 16
May 5th, 2017 03:13 AM #16just want to share a similar problem and what was done to fix it.
Problem: delay during cold start. may 10-15 seconds delay kapag nilagay sa D. so ang ginawa ko, pinapainit ko muna ang makina ng 2-3 minutes. umokey siya, until one time, kahit na more than 10 minutes nang mainit yung makina, ayaw namang umatras (pero nakakaabante). this was even after mapalitan ng ATF 2 months ago. so I decided the next day na dalhin sa transmission specialist yung sasakyan.
Solution: di ko nakita exactly kung anong ginawa since kumain ako nung nirrepair nila, pero nakita ko initially na dinrain nila yung ATF (since relatively bago siya, at weekends lang naman ginagamit ang sasakyan). nung nagtanong ako, sinabi na bumili sila ng isang litro ng gasolina tapos yun ang pinatakbo sa transmission. then ibinalik nila yung lumang ATF, then nag top-up na lang uli ng one liter. the day after, meron pa ring delay. pero after another day, nawala na yung sakit.
Shop: Caintic Motorshop in Valley Golf, Oritgas Ave extn, Cainta (between Jollibee and Metrobank). Landline: 261-1687
- Jun 2005
- 3,774
May 5th, 2017 01:55 PM #17^Dapat palitan mo uli ATF mo. May naiwan na gasolina yan sa loob ng tranny that will cause degradation ng ATF mo.
May 5th, 2017 06:32 PM #18
Thank you for the warning ... will avoid that shop ... your Automatic Transmission will soon self destruct unless you change and flush it with the proper ATF ...
Xiaomi E-Car
