Results 11 to 20 of 20
- Jun 2005
- 155
October 25th, 2009 01:58 PM #11they replaced the automatic tranny of my pajero for 25thou.And I had a 2003 honda city idsi whose shifting was sluggish, they replaced the sensor 5thou lang.They will replace only the parts that needs replacement.They also fix the wiring,sometimes kasi thats the root of the problem and not the tranny itself.
- Jun 2005
- 155
October 25th, 2009 02:10 PM #1260thou would be the cost if you replace the whole engine na!Just look for Mang Arcing and he will give you an estimate for the repairs to be done.Sometimes he does home service to my shop here in Mindanao Ave but the parts still comes from Banaue so its better if the repairs would be done in baltak banaue.
Sometimes its hard to diagnose a tranny problem on a particular vehicle,like the imported mitsubishi spacegear that I had.It took them 3 tries before finally fixing the problem.
If so many parts needs replacement, tip ko lang na suggest mo na palitan na lang the whole tranny.
- Oct 2009
- 9
October 25th, 2009 07:25 PM #13Thank you for your reply. Should I still have my transmission cleaned before going to Baltak and hope that it gets fixed or should i just go straight to Baltak? If i have it repaired in Baltak, will it take them more than one day to repair or replace the tranny?
- Jun 2005
- 155
October 26th, 2009 11:33 AM #14
THE AUTO SPECIALIST
- Mar 2006
- 607
October 27th, 2009 06:32 AM #15you will be able to flash the codes by grounding the terminal #1 from diagnostic connector . turn the key off and ground the said terminal ,ignition on ,and read the N - light flashes.
October 28th, 2009 10:44 AM #16
does anyone here know if the '97 accord is equipped w/ an atf filter? may nagtatanong kasi sa akin and i don't know the answer to that
THE AUTO SPECIALIST
- Mar 2006
- 607
- Oct 2009
- 9
February 23rd, 2010 03:41 PM #18Up ko lang ulit ung post ko kasi hindi pa naayos. Pag malamig naman yung kotse (galing sa parking at naka ilaw ung blue na temperature gauge sa dashboard) ok naman yung takbo ng kotse, pag uminit lang, mahirap na yung hatak. Patulong lang po ako.
- Oct 2009
- 9
February 25th, 2010 05:59 PM #20pumunta nako. pero hindi rin nila maayos ayos. nagpalit nako mga sensor sa kanila. wala pa din. Pero pag malamig naman yung kotse, ok naman takbo niya, yun lang pag nag init na, wala na.
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
