Results 1 to 16 of 16
    Feb 2017
    What is likely affected when you're in reverse and slowly release the clutch then you starts moving forward because its a downhill, around 10 meters , my screetching sound habang umandar. After that incident anu kaya ang tinamaan?
    Quote Originally Posted by Gspeedy View Post
    kindly re-phrase your story, po.
    magulo.
    un-gettable.
    Dec 2013
    The way i understand it, the driver was slow to shift. When he finally gets it into reverse, the car was already rolling forward because of the incline. Methinks the screeching came from the wheels suddenly jerked into reverse while going forward.
    Sent from my LG-D855 using Tapatalk
    Jul 2016
    If it is not the tires screeching it could be the clutch. So to answer your question, it could be the clutch schreeching, a sign of a little overworked on that scenario.
    Feb 2017
    Hi sorry mga sir medyo magulo nga. Umatras kasi ako noon going out sa parking na inclined, so nung naka atras na nag clutch na ako while still in reverse making the car move forward but forgot to shift to 1st gear.
    So while naka reverse i was slowly releasing the clutch while moving forward on the steep inclined, i heard screetching.
    I's suspecting pambelt becuase it sounded like one, but some article are point to trans and engine. About 5-10 meter yun tinakbo niya before ko narealize na nakareverse.
    Feb 2017
    Actually it was my girlfriend who was driving then. Medyo tinuturuan ko pa and we both failed to notice right away.
    what comes to my mind that causes such screeching sound:
    1. idler pulley needs lubrication. now, we know that lubricating it is just a first aid measure. replacement is the long-term solution.
    2. fanbelt slippage. maluwag... nabasa... service it only. no need to replace, unless it already shows cracking.
    3. smokin'tires! but i don't think this is your cause.
    Feb 2017
    Paano mo malalaman kung Idler Pulley may symptoms ba, easily check by mechanic? Mahal ba palit nun?
    Jan 2009
    The clutch shouldn't make that noise. My guess is that what you heard was the belt. It was just pure coincidence that the noise appeared while you're still in reverse and moving forward.
    BUT, if you were already coasting downhill for 5-10 meters, there would've been enough build up of speed for the tires to squeal when you released the clutch while in reverse.
    if it's the idler pulley, it will remind you of it from now on. i-ingay at i-ingay yan sa hinaharap.
    Jul 2016
    Volkswagen Clutch Noise (chirp / Hoot) - YouTube
    Honda Civic First Gear Clutch Noise-8th Gen Civic Si - YouTube
    You can easily check if it came from belts, just do a quick hard rev sa engine. If its the belts, it will sound.
    Feb 2017
    Quote Originally Posted by Janemar View Post
    Thanks for all the input guys.
    Actually i was slowly releasing the clutch, as it was downhill- trying to engine break, when i heard the squeeking sound. I pressed the clutch again and sound is gone then slowly releasing it again and the sound again just then i realized and notice that i was still in reverse. After that i shifted to first gear and car drived then as normally. I will have the car check soon maybe i'll have all your inputs to be check by mechanic. By the way the pambelt is new also.
    some "pambelts" need a bedding-in period, po, after which, belt tension is re-adjusted if necessary. not all cars have idler pulley.
    Jan 2010
    Sus ginoo, gerlpren pala ang nagadrive. Magulo pa Rin.
    Oct 2009
    okey lang yan.ganyan ginagawa dati ng tiyuhin ko dati sa baler nung nag byabyahe pa kami ng mga troso.pag pababa at medyo madulas ang kalsada naka shift siya ng reverse..
    Feb 2017
    Quote Originally Posted by jaypee10 View Post
    Pwede pala yan eh di sliding yan.
Slowly Rolling downhill while in reverse(m/t)
