Results 1 to 15 of 15
    Apr 2009
    Ive noticed some stiffness when i change gears especially if im on the road for like an hour already. But sometimes its really soft when its raining or if weather is cold. What could be the problem? 1997 Corolla gli 1.6 here.
    Jul 2016
    Baka clutch master yan sir. Ganyan din dati sa small body corolla ko. Palit lang ng clutch master. Tumino naman. Tnx
    Sent from my SM-J500G using Tsikot Forums mobile app
    Feb 2009
    Quote Originally Posted by bail View Post
    At the transaxle end of the shifter cables, there are two quadrant bellcranks, each cable end have a square bushing. These bushings dry up over time. Relubricate with multipurpose grease.
    Apr 2009
    How much labor for this type of diagnosis?
    Jun 2016
    SIR,
    basta open lng ba ung takip ng kambyo then lagyan ng grasa lahat ng maabot ng kamay mo?
    how to do it properly ba?
    Jul 2006
    Have you replaced your tranny oil? What viscosity? Sounds like you need a tranny oil change (with the correct grade).
    Case in point, Classic Mercedes Benz manual transmissions specify ATF (go ahead, google it .. ..). If the mechanic servicing it is clueless, then loads up on ordinary hypoid gear oil, the owner of the car will experience "maganit" shifting when first driving the car in the morning. As the transmission heats up and the oil thins out, normal shifting is experienced.
    In your case, the tranny oil maybe good when cold, but thins way out when it heats up, thus you experiencing stiffness.
    My 2 cents.
    Dec 2016
    Good pm. Tanong lang ako ho ako ng subok na shop cavite area, taga imus po ako. Gusto ko sana ipacheck at ipaayos kung anong sira sa clutch/transmission ng sasakyan ko, ang ganit(mahigpit) tapakan ng clutch/hard shifting especially 1st gear, kapag reverse dahil nga din siguro ang ganit tapakan ng clutch hindi ko gaanong natatapakan minsan kaya tumutunog/nabibitin pag kagat sa reverse. Last major pms 45k km ko was this year march, hindi natingnan yung clutch/tranny dahil hindi ko din naipacheck(1st time sa casa/walang pang alam.)
    Oct 2014
    Quote Originally Posted by susikey View Post
    See Victor the mechanic at Petron Bacoor. Maybe slave cluth cylinder/Repair kit replacement only.
    May 2016
    Same rin po ba if mahirap mag gear sa 1st gear lang? The 2nd to 5th to R swabe naman
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    Hulaan natin sasakyan mo. Ito ba ay 2006 na toyota vios mt?
    Dec 2016
    Suzuki Dzire 2013 mt po sir salamat sa feedback. Medyo nagamit kasi namin yung sasakyan sa pagaaral ng gf ko nung nakuha namin on its 2nd yr. Wala pa akong alam sa sasakyan kaya hindi ko alam bakit tumigas yung clutch and naghahard shifting. Dinala ko naman sa casa netong march pero hindi naentertain yung concern ko siguro hindi ko din masyado naiaddress, pms lang talaga nagawa.
    Jan 2017
    Hi mga boss, yung sa akin po naman ay pag nagbabawas ako ng gear tumutunog lagi kahit sobrang tapak ko na sa clutch. sabi po kasi bka daw kulang lng ako sa tapak. thanks po... 1st gen kia sportage po sasakyan ko.
Manual gear stiffness
