Results 1 to 10 of 14
- Aug 2012
- 51
October 5th, 2012 03:04 PM #1Gurus, Naramdaman ko lang to ng magpalit ako ng Spark plug. pero di ko alam kung transmission problem naba to or Advance lang yun timing na ginawa ng SERANIKO na napuntahan ko samin. need you inputs about this please.
Spark plug - Nagpalit ako ng Spark plug from 3 NGK + 1 Bosch to 4 Bosch. after replacing my spark plug naramdaman namin na hirap mag start kaya may adjustment na ginawa yun mekaniko ko dati. after the adjustment, 3 times need i switch yun start para mag tuloy, yun first 2 attempt puro redondo lang at ayaw mag tuloy pag dating sa pangatlo ayun nagtutuloy na at malakas yun nginig feeling ko mataas yun idle e.
tsaka kapag umaandar na yun sasakyan mabagal sa arangkadahan although A/T to. At kapag free way halimbawa 40mph na takbo at unti unti ko tatapakan yun gas bigla bigla lalakas yun tunog pero yun takbo mo mabagal pa din. nadidinig ko yun tunog na nung makino ko malakas na pero yun takbo ko wala pagbabago kaya gagawin ko bitaw sa gas then dahan dahan ulit ayun magiging ok na. lage to kapag papanik ng 60mph yun speed ko. Nung di naman ginalaw yun idle ko dati ok naman siya mabilis pa nga e. Parang advance yun engine pero yun takbo wala respond. palyado ba matatawag to?
October 5th, 2012 04:51 PM #2
pwedeng wala nga sa timing yung engine or sira yung torque converter ng oto mo TS.
October 5th, 2012 04:57 PM #3
- Aug 2012
- 51
October 5th, 2012 05:02 PM #4
- Aug 2012
- 51
October 5th, 2012 05:14 PM #6
do you have distributor type ignition? you mentioned about ignition timing being mcgyvered. some of these cars have coil-on-plug (COP) ignition system and you can not adjust ignition timing unless you flash reprogram the engine computer. for you to check if it was your engine or your automatic transaxle that is giving you the problem is to do a forward stall test and reverse stall test. what these are: with the engine warm, appply parking brakes, chock your drive tires, have a tachometer installed if the car is not equipped and rev the engine with the trans in drive and brakes applied. observe the highest engine rpm. do the same procedure in reverse with the chocks in the opposite side of the tires and record the max engine rpm too. post your results for additional help.
October 5th, 2012 07:22 PM #7
October 5th, 2012 08:00 PM #8
the pump produces the pressure. the torque converter acts as a hydraulic coupling between the flexplate (flywheel) and transmission input shaft. the torque converter multiplies the torque during the vortex flow and goes into rotary flow soon as the rotational speed of the input closely matches that of the output rpm. see autoshop101.com/forms/AT02.pdf
- Aug 2012
- 51
October 5th, 2012 08:37 PM #9
October 5th, 2012 09:39 PM #10
very well said mate.. cheers
As additional info.. there are four components inside the torque converter, to wit..
Pump
Turbine
Stator
Transmission fluid
A torque converter is a type of fluid coupling, which allows the engine to spin somewhat independently of the transmission. If the engine is turning slowly, such as when the car is idling at a stoplight, the amount of torque passed through the torque converter is very small, so keeping the car still requires only a light pressure on the brake pedal. (HowStuffWorks "Basic Torque Converters")Last edited by phezthie; October 5th, 2012 at 09:53 PM.
VinFast VF 3
