Results 1 to 14 of 14
    Feb 2009
    Quote Originally Posted by jon_i9100 View Post
    Gurus, Naramdaman ko lang to ng magpalit ako ng Spark plug. pero di ko alam kung transmission problem naba to or Advance lang yun timing na ginawa ng SERANIKO na napuntahan ko samin. need you inputs about this please.
    Spark plug - Nagpalit ako ng Spark plug from 3 NGK + 1 Bosch to 4 Bosch. after replacing my spark plug naramdaman namin na hirap mag start kaya may adjustment na ginawa yun mekaniko ko dati. after the adjustment, 3 times need i switch yun start para mag tuloy, yun first 2 attempt puro redondo lang at ayaw mag tuloy pag dating sa pangatlo ayun nagtutuloy na at malakas yun nginig feeling ko mataas yun idle e.
    tsaka kapag umaandar na yun sasakyan mabagal sa arangkadahan although A/T to. At kapag free way halimbawa 40mph na takbo at unti unti ko tatapakan yun gas bigla bigla lalakas yun tunog pero yun takbo mo mabagal pa din. nadidinig ko yun tunog na nung makino ko malakas na pero yun takbo ko wala pagbabago kaya gagawin ko bitaw sa gas then dahan dahan ulit ayun magiging ok na. lage to kapag papanik ng 60mph yun speed ko. Nung di naman ginalaw yun idle ko dati ok naman siya mabilis pa nga e. Parang advance yun engine pero yun takbo wala respond. palyado ba matatawag to?
    you have identified your spark plugs but you have not identified your vehicle. what make, model, year and mileage do you have. what transmission family do you have?
    Aug 2012
    I'm sorry my car is Nissan/2001/Sentra 151(Exalta like)/89,000. Sir, A/T Transmission is that what you mean by family transmission?
    - Noob here :|
    thank you
    Feb 2009
    - Noob here :|
    thank you
    do you have distributor type ignition? you mentioned about ignition timing being mcgyvered. some of these cars have coil-on-plug (COP) ignition system and you can not adjust ignition timing unless you flash reprogram the engine computer. for you to check if it was your engine or your automatic transaxle that is giving you the problem is to do a forward stall test and reverse stall test. what these are: with the engine warm, appply parking brakes, chock your drive tires, have a tachometer installed if the car is not equipped and rev the engine with the trans in drive and brakes applied. observe the highest engine rpm. do the same procedure in reverse with the chocks in the opposite side of the tires and record the max engine rpm too. post your results for additional help.
Sliding transamission? A/T
