Results 11 to 20 of 22
- 290
January 3rd, 2003 12:22 PM #11melea, mukhang hindi mo napalitan yung release bearing or hindi mo lang nabanggit?
- 237
January 4th, 2003 11:05 PM #12correct kayo sir z,
kasi dad ko, medyo nagtipid na naman....ayuun....pinalitan lang ung plate...kasi pudpod na sobra, tinamaan na nga ung clutch disc, e pwede pa naman daw kasi orig...no choice...pera ng dad ko un eh...
- 290
January 6th, 2003 10:52 AM #13melea, masasayang ang pressure plate kapag nagkaproblema sa release bearing. yung release bearing ang reason kaya nauupod yung plate. kapag bumigay na yung bearing or about to retire na eh malamang maupod na naman yung bagong pressure plate. anyway, malaman mo naman dahil maingay yang release bearing.
may nakasabay ako nagpagawa na parehas ang kaso. pressure plate lang pinalitan and after a few months baba ulit dahil nagloko na yung release bearing. halos nadeform na yung release bearing hindi na perfect circle and eventually nasira din yung kapapalit lang na pressure plate. ayun, pinalitan niya na lahat.
- 237
January 6th, 2003 08:54 PM #15hmm...how would i know kung may tama na ung release bearing?
hmm...this past few days..medyo naging okei naman...ang problem ko lang is medyo mataas ung clutch ko....di kaya un problem ko?kasi nasanay ako dun sa adventure namin na mababa ung clutch...
- 290
January 7th, 2003 11:55 AM #16maingay naman yang release bearing kapag may problema na.
paadjust mo muna clutch mo then drive in such a way that will maximize buhay ng clutch assembly mo sayang din naman kasi yung bagong pressure plate.
- 45
February 5th, 2003 07:28 PM #17yung Mazda GLXi namin ayaw mag-engange yung gears. ayaw pumasok ng kambyo sa gear. parang may nakaharang sa pathway ng pag shift mo. kapag patay makina nakakapag-shift naman ng parang normal lang pero kapag nka-on na yung engine ayaw na talaga... ano ba problem nito and pano to masusulusyunan? tnx for your replies in advanced!
- Nov 2002
- 25
yebo8 GuestFebruary 5th, 2003 09:09 PM #19
mazda 323 un kay erpats e pero bka pareho lang
check the ff:
1. check the clutch adjustment gaya ng sabi sa itaas
2.. check the gear shift lever bushing. plastic lang yun baka pudpod na. mura lang yon, P60 yata. this is like a cup at the bottom of the gear shift lever, dali lang palitan yan. even you can do it, tanggalin mo lang yun kambyo hugutin mo, then nasa tip yun ng lever.
3. pag wala sa 2 yan, synchronizer gear and synchronizer keys na yan. in other words, overhaul transmission ka na. yari ka, tsambahan yan kung available sa banawe or anywhere, kahit sa casa ng mazda wala yan. o-order mo pa yan sa columban motors sa tramo, 6 months ang lead time nila. bili ka ng surplus na transmission mas mabuti pa.
- Feb 2003
- 4
March 2nd, 2003 03:57 AM #20Sgt trigger,check the adjustment or betteryet,have it checked by a mechanic.baka may leak na yung master at nauubusan ng clutch fluid kaya ayaw na kumambiyo.I dont think sira ang buo transmission mo kse may maririnig ka tak tak sounds from below pag ibaba na :wink: Sana lang...SANA...:lol:
Traffic!
