Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 53
    Jan 2003
    #31
    There are situations that the A/T logic can be confused, especially on a long uphill climb. The end effect could be that your A/T would continuously cycle between gears as it hunts for the best torque suitable for that climb. The L and 2 settings are a way to prevent this as you pretty much have full control of your speed of accent and RPM. You can then shift to D as road conditions improve.
    If your A/T has grade logic or similar fuzzy logic intelligence, it may retard the up-shift but they're still subject to certain programming limitations.
    That's true. My point was, this and a few other situations which warrant 2 or L are not typical, hence the average Juan drivers can usually get away with just using D. ;)
    Aug 2007
    #32
    if going down from the 4th level of the MOA covered parking, saan dapat ang gear--D? or D2?
    #33
    Quote Originally Posted by silver streak View Post
    L mode.
    Dec 2008
    #34
    Just use D
    2 and L are just used for extreme conditions. Going down the mall ramp isn't one of them. 99.95% of driving conditions can be handled by the D mode of the A/T
    2 is used mostly for low grip conditions (ICE) to prevent wheel spin
    L is used for heavy load engine breaking on very long downhills (miles long downhill, not going down parking ramps) where there is a big chance you can overheat the brakes.
    D can cover most conditions, it automatically downshifts when going uphill and when the gas pedal is suddenly jammed into the floor (triggers emergency downshift mode, only upshifts when the pedal is released a little bit).
    Remember 2 and L puts some stress on the engine and transmission components, it is easier to put the wear and tear on the brake pads than the transmission as long as you don't overheat the brakes. most brakes don't overheat that quick anyway.
  5. #35
    moa yan..mahaba corkscrew incline nyan when entering/exiting... kung nababagalan ka sa L, 2 is ok.. pero kung D uubusin/paiinitin mo lang ng labis ang preno mo...
    #36
    i was here yesterday. i just used D.
    #37
    tama, depende sa flow. kung libre kahit 2 but kung tutukan L or 1 for sportronic.
    #38
    Quote Originally Posted by alwayz_yummy View Post
    MOA carpark lang yan...D lang yan
    Aug 2007
    #39
    sa totoo lang mga pipol ay hindi ko pa nagamit and D2 and L (honda civic vtec)...on D lang ako when driving...flat terrain naman always ang tinatahak ko e.
    pero dito sa MOA covered parking area na corkscrew nga ang shape...sa pag-EXIT/pababa (either from 4th or 3rd level), i would be in D, maluwag man or meron pila going down. minsan i would release pa my foot from the accelarator pag maluwag...hahaha...pero alalay sa brake...yun nga lang, palagi ko naiisip what it will do to my brakes when at D going down/exiting the corkscrew parking ramp of MOA.
    btw, malakas ba makabawas ng brake fluid kaya yun pag ganun ang gagawin--meaning, sa D going down the MOA covered parking area?
    Dec 2007
    #40
    Yung brake fluid po ay ginagamit lamang na pangtulak ng brake pistons, bumabalik po ito sa reservoir pag binitawan na ang preno. Kaya matagal bago ito mabawasan.
    Kung hindi magkaroon ng tagas ang brake lines/system mo, baka mauna pang maubos ang brake pads kesa sa brake fluid.
    Sa matagal na babaan sa parking, para bawas wear sa brake pads, oks yung L/1 or 2.
Questions regarding A/T- D, 2, L?
