Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 169
    Guys! I have a question re A/T. I have a new car with A/T and i'm having a hard time adjusting to it since all my life i have been driving a manual. There are a lot of things that confuses me. Maybe some of you can help and clarify it once and for all. When in stop and go, should I still shift to N or just remain in D with the brakes pressed or hand brake? How about in stop lights, is it better for my transmission to just stay in D with the hand brake or should I move it to N? I am confused since some people say its ok to shift from D to N when the car is not in motion but some say it is bad for the transmission. Medyo magulo na talaga. Please help. I want my new car to last and be able to drive it correctly para tumagal yung transmission without defects. Thanks a lot!
    Put it in neutral whenever you stop.
    You don't need to shift to N, when you press the brakes fully and the car isn't moving, there's no need to shift to N, makes little to no difference. Same token, won't hurt if you do shift to N.
    But based on logic, the less you move the shifter, the less wear on your control cable and torque converter (since it has to re-engage when you shift to D again).
    Personally, unless it's a long stop, I let it stay in D. If it's a really long stoplight stop or I have to park, then it goes to P + handbrake.
    Sep 2004
    since the beginning of my driving experience and from reading car manuals, it is mentioned not to move the shift level from "D" to "N" when in stop and go traffic.i know that it is more smooth if its in N while waiting for the light to turn green, but the movement from N to D to N and vice versa has more wear and tear as "Theveed" mentioned previously. if you notice, there is a slight jump from N to D. so best practice is to remain in "D" and only shift to N if its more than 1 minute waiting period for the light to turn green.
    I was taught that in drivers education back in high school, although they taught and gave more reasons why it should be left in "D" while at a stop light.
    Jun 2005
    on your concern to be able to drive it correctly . . . .
    most auto-trannys have pre-set shift points. Some have economy and power buttons (like mitsu's). Know your cars AT shifting points so you don't unneccessarily over-rev your engine. Also check the rpm when your torque converter locks up - this is when you have a speed gain of say from 60 kph to 80 kph but your rpm remains pegged at 2,000rpm - that's your torque converter locking up (wala nang slippage) delivering additional speed without engine having to rev up higher (this was on my old D16Y8 AT).
    Drive it right, an AT doesn't necessarily mean higher fuel consumption.
    how bout downhill,guys?leave it in D or freewheel on N like on a manual tranny?i always do D but i'm just thinking maybe i'll save on gas if its not on drive
    Just don't make it a habit to stay in "D" for too long. My friend fell asleep one time and he woke up with a thud.
    Nakatulog, umangat ang paa sa brake. Bangga sa bumper ng auto sa harap niya. If it will take more than a minute, put it in N then handbrake.
    Play heavy metal music para di antukin. Optional.
    Aug 2004
    I have one very good reason for you to shift into N at the stoplight. ATF temperature.
    Whether or not you shift into Neutral, your torque converter will have to re-engage anyway when you pull out from the stoplight, as it's disengaged completely at idle. I usually just shift back into D before releasing the brakes.
    While the torque converter is disengaged at idle, it's still connected as long as you're in D. While you're in D at a stop, there's more friction, as the torque converter is torn between the transmission wanting to push the car forward and the brakes holding it back. This causes more heat in the Automatic Transmission Fluid as it is pushed through the torque converter, and more pressure on the brakes.
    Hot ATF in traffic can cause premature wear of the transmission. Hot brakes also wear down more quickly. There's a reason AT cars eat up brake pads like rice cakes and require new brake discs more often than manuals.
    Most driving instructors don't want you to shift into neutral while the car is moving, as you can't react to road emergencies right away, but at the stoplight, you're not going anywhere anyway.
    So... if the light has just turned red... shift it into N. Save yourself some brake pad, and keep your ATF cool.
    Aug 2004
    Oh, downhill? Leave it in "D". Or "2" if it's a steep descent. More controlled. Not good for your ATF if you're freewheeling the whole time, but safety first.
    Quote Originally Posted by wulf
    how bout downhill,....freewheel on N ...save on gas if its not on drive
    that is the best way to damage an auto tranny, moving while on N. that is why the manufacturers recommend that if a car with auto tranny will be towed that the drive wheels be lifted, because the tranny must never be shifted to N (or P!) if the car is moving.
    Sep 2004
    niky brought up a good point. thanks for that. but i disagree on this portion "if the light has just turned red... shift it into N. Save yourself some brake pad" if your already come to a halt, and just pressing the brake so it doesnt move, I don't think you are wearing the brake pads. just more pressure sa brake master.IMO.
    Yes, never shift to N sa AT pag gumagalaw hehe...
    Use logic, use common sense when determining when to shift to N, kung sobrang short stop, meaning nakikita mo nadin naman that the light will turn green soon or the traffic ahead will be moving in a few secs, don't bother moving it to N. But if you're faced with a 1-2 min stoplight or a jam, doesn't make sense to keep it in gear.
  13. #13
    thanks for the info niky.
    Pansin ko lang sa ibang mga drivers, on a stoplight the shift it to "P", I don't know if this puts more wear on your A/T. I usually keep it at "d" during short stops, then shift to neutral if traffic is heavy.
    Quote Originally Posted by yebo
    Quote Originally Posted by theveed
    Do you know why this is so? Sa manual, ok lang naman mag neutral at freewheeling right, or hind rin? What happens sa matic tranny if you place it in neutral while the car is moving, say freewheeling?
    This might help understand the complex nature of AT...
    http://www.familycar.com/transmission.htm
    http://www.2pass.co.uk/auto.htm
    FAQ about Automatics:-
    In a automatic car when you stop at lights or at a give way sign do you need to put the car into "park" or "neutral" or put the handbrake on in either of these , or just brake?
    From time to time you will stop in traffic. On these occasions you need to make sure that the car is secure. Whether driving a manual or automatic, it's a good idea to use the handbrake to secure the car when you stop for more than a moment. This helps to prevent the car from being shunted forward if hit from behind.
    In an automatic it's even more important to use the handbrake; if you are hit from behind the car will try to take off! Stay in drive so that you are ready to move and apply the handbrake firmly.
    If waiting a long time, apply the handbrake and then select neutral. This removes the chance of 'creep' if the handbrake is not securely applied.
    When parking use the 'park' position as soon as you stop. This locks the transmission.
    Aug 2004
    P is just pushing it... kung matamaan ka ng ibang kotse... eh di sira din ang parking brake? Just use the E-brake or handbrake if you're going to take that long... :lol: ... N is enough, if you're on your brakes.
    Even if the car is at a complete stop, having it in D while on the brakes still means the engine is pushing against the brakes. Tama ka rin, not much more wear on the pads, but you're using gas and heating the ATF for nothing. If it's going to be a longer than fifteen second stop, putting it in N is a good idea.
    Oct 2005
    putting the transmission to N while downhill gives your brakes a hard job. use 2 instead or L so that the engine will brake for you... pero wag ka magsshift pag mabilis ka pa...doing so will damage the engine naman. pero..imo...mas matibay ang A/T kesa M/T...
  19. #19
    its still best leave it at "D" when coasting or on a downhill stretch...
    In most level driving scenarios, the A/T is set to D at all times. If for some reason I'm stuck in traffic and can't move, I put it in P and keep an eye out for movement up front.
    Downhills have always been problematic especially along the Rockies and the Sierra Nevadas where long, steep downhill stretches raises hell with brakepads. I prefer a combination of brakes and engine-braking to slow me down. But, that's not always possible with a pure automatic.
    That's why an automanual like a Tipronic or Shiftronic is the best of both worlds.
Question re Automatic Transmission Driving Technique
