Results 1 to 10 of 21
January 15th, 2008 11:12 AM #1
especially sa incline parking... when you shift it to "P" do we still need to release the brake pedal first and let the car slide a little for the tranny to engage/lock or we can just pull up the hand brake and leave w/o allowing the tranny to lock first? what is the right way?
January 15th, 2008 11:20 AM #2
i was told when I took drivers ed is to just place tranny in park position and lift the parking brake lever then release your foot off the brake. Its not recommended to let the transmission hold the car on the hill, thats why the brake lever is there, the transmission lock is there for safety in case your hand brake gives way or not as strong. Another thing that was taught is to know where to turn your front wheels depending if downhill or uphill.
January 15th, 2008 11:49 AM #3
Tsikot Member Rank 4
- 2,719
January 15th, 2008 12:11 PM #4i agree with "park brakes" should hold the car in place, not "P" transmission lock.
January 15th, 2008 01:57 PM #5
i don't drive automatics, but i think the common sense is:
a) step on the brake pedal
b) switch the AT lever to P
c) pull the handbrake
d) remove your foot on the brake pedal
e) turn of the engine.
tama ba?
January 15th, 2008 02:13 PM #6
- May 2005
- 277
January 15th, 2008 02:21 PM #7on more severe inclines its better to pull the handbrakes first before putting it in park otherwise there will be difficulty releasing from park to reverse, when you restart the car..on level parking any sequence would be fine
January 15th, 2008 02:41 PM #8
- Jan 2007
- 2,326
January 15th, 2008 02:43 PM #9
January 15th, 2008 03:02 PM #10
yup.. ako din.. break parati before start.. naging habit na..
parang sa stoplight.. pag medyo matagal.. do you shift to N then hand break then release break or hand break then shift to N then release break?
Eto yung best chance mo for troubleshooting kung saan ba talaga galing leak. Also, precaution...
Coolant...
