Results 21 to 30 of 30
December 7th, 2019 09:31 PM #21
- 52,731
December 7th, 2019 10:32 PM #22
December 8th, 2019 04:43 AM #23
What I was taught is to depress the brakes, put the gear in neutral then start the engine.
Since it was just an assembled vehicle, it has no parking brake. Later on with experience, it became a habit even if I'm using a car with handbrake.
My experience, or rather the experience of others, with some of them I have personally seen, not to rely on the handbrake. I've seen a couple of them, where the handbrake didn't work and so caused a lot of damage. One hit a store on the opposite side of the road, one hitting the walls of the garage, and others I couldn't remember.
Then there's this guy who immediately depressed the clutch, without depressing the brakes first. The vehicle moved backwards, as it is in an inclined road, almost hitting the car behind 3 meters away.
- 52,731
December 8th, 2019 08:45 AM #24well, i have my own opinion on folks who do not equip their backyard-assembled cars with a hand brake.
in decades past, the absence of functioning handbrake, was a mainstay of assembled owner type and passenger jeepneys.
"hijo, i-segunda mo lang, at parang naka-handbrake ka na."
heh heh.Last edited by dr. d; December 8th, 2019 at 08:59 AM.
December 8th, 2019 03:32 PM #25
- Sep 2006
- 2,746
December 8th, 2019 04:01 PM #26It's a safety feature alright, and I'm sure they did extensive research to decide on choosing pressing clutch as a requisite start to machine, still my instinct tells me, the brake pedal is a better choice if we talk of safety
- May 2006
- 1,668
December 8th, 2019 04:39 PM #27Then you won't be able to push start an MT vehicle.
- 52,731
December 8th, 2019 08:06 PM #28the brake pedal is the better choice to step on, when starting an automatic.
when starting a MT, stepping on the brake pedal will still result in a rude shaking up, if the trans was in gear when the starter is activated. this will not happen, if it were the clutch pedal that was stepped on.
in either case, pulling on the handbrake before starting, is always a good move.
and yes, vehicles without a functioning handbrake should not be given permission to use public roads.Last edited by dr. d; December 8th, 2019 at 09:08 PM.
- Nov 2009
- 3,484
December 9th, 2019 09:01 AM #29Passing LTO driving exam does not warrant safety over the basic operating principle of the car because technology evolves rapidly.
By reading the user manual before operating the machine, the manufacturer guarantees safety and functionality iff followed correctly. Ignorance and negligence by the operator is beyond the manufacturer's responsibility.
- 52,731
December 13th, 2019 09:49 AM #30what i do is to look for the specific topic in the booklet, and limit my readings to that couple of pages only.
some owners are not lucky. their used cars came without that owner's manual.
there is value to listening intelligently to the driving school's lecture series.
but it is not easy, because the pupils therein aren't yet versed with their cars and the road rules, and probably do not know what the lecturer is talking about, because they can't connect...Last edited by dr. d; December 13th, 2019 at 09:53 AM.
high idle RPM at engine start
