Results 1 to 5 of 5
- Dec 2011
- 14
December 3rd, 2011 05:03 PM #1mga sir pahelp nman po bumili ako ng secondhand use na 2000 pajero 4x2 and khapon im running 95km/h at 3500 rpm na anu kaya ang problema mga sir? Nka OD on nmn po ako,prng ayaw magshift sa 4th gear.Sana matulungan nyo ako.Salamat
- Aug 2009
- 48
December 3rd, 2011 06:44 PM #3
the overdrive works only after the enable criteria had been met. those are, coolant temperature about 170 degrees fahrenheit or higher, vehicle speed about 32 mph, throttle opening about thirty percent. if one of the values for enable criteria ismissing, the overdrive does not engage even if your O/D button is set to overdrive. overcooled engines never get to overdrive.
- Dec 2011
- 14
- Dec 2011
- 14
just done 10,000 km already replaced the transfer case fluid w/ ravenol MZG 90. a lot thicker...
Suzuki JIMNY [merged threads]
