Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
    Apr 2005
    #21
    Quote Originally Posted by nugundam93
    afaik when overtaking, you don't actually need to turn off o/d, kasi baka mabitin ka pa, lalo na at high speeds where the top gear is needed. :D
    and the 5-speed matics na pajero iirc were the gen3s na, invecs-type.
    4m41 + 5-speed invecs = t3h w1n. :D
    Thanks! nugundam93! galing yan INVECS!!
    O..V22 abangan mo na surplus na INVECS transmission baka pwede yan sa 4d56? hehehe..
    #22
    hehehe, sarap nga idrive yung gen3 pajero (gas or diesel) with the invecs. iwan mo sa 4th gear at 40kph, it'll run along with no questions asked. :D
    i think pwede naman invecs for the 4d56, but the shift points also have to be optimized for the 4d56 too...
    Apr 2004
    #23
    oo ganda ng INVECS! lalo na pag feeling sporty ka.. ;)
    accs.. regular change ATF lang yan...
    #24
    Tranny overheating can be commonly caused by overloading, a/t cooler malfunction, low atf level among others.
    Yes, a/t's will consume more pads than m/t's. But pads are not terribly expensive. And it will just usually be the front ones.
    GEN II and 2.5's are 4speed a/t (1-3 + O/D).
    And you mash the gas pedal when passing because you only want to be in the opposite lane for the shortest possible time. After you pass and let up on the throttle, the tranny will upshift back into the correct gear almost instantly.
Pajero Automatic
