Results 1 to 10 of 24
- Mar 2004
- 652
March 29th, 2005 08:28 PM #1Mga peeps,
Me nagpapatanong sa akin regarding Pajero Automatic, naka turbo-intercooler.
Ano ang problema kung hindi pumapasok ang over-drive shifting?
Pwede ba mag inputs dito, mga sadiq?
Thanks.
March 31st, 2005 01:44 AM #2
Pano niya nalaman na hindi nag-overdrive?
- Mar 2004
- 652
April 4th, 2005 12:55 AM #3Sori, Mr. Otep, ngayon lang ako nakababa sa sibilisasyon. Ang sabi ng kaibigan ko, kapag nasa 3rd gear na raw (nakarekta na sa hi-way), pag shift niya sa overdrive, wala response o additional accelaration na maramdaman. Di ko rin masyado mapaliwanag kasi I'm not familiar with the automatic drives.
April 4th, 2005 01:07 AM #4
Pushbutton ang overdrive ng Pajero. He is supposed to leave it on. Pinapatay lang yun when going up or down steep grades for extended periods.
And when you shift to overdrive, dapat bumaba ang revs mo. Kasi, overdrive is equivalent to the top gear of a manual tranny. (some people actually think that overdrive is a turbo boost thing). So kung ano ang response ng Pajero manual when you shift into 5th, yun din ang response ng Pajero A/T when it goes into OD.
Btw, ako naman ang mawawala sa sibilisasyon for the rest of the week.Trabaho na naman.
- Mar 2004
- 652
April 4th, 2005 07:49 PM #6Thanks for the reply Mr. Otep. medyo na-misconception lang siguro ang kaibigan ko sa term na OD.
BTW, sabi mo ikaw naman mawawala sa sibilisasyon. talagang kelangan kumayod para me pang-gas(tos) sa mga kabayo natin
April 10th, 2005 08:39 PM #7
Andyan naman si nugundam kapag wala ako.
I'm back. Tuesday ulit ang balik ko sa Bulacan.
April 10th, 2005 10:05 PM #8
question lang mga peeps.. is it ok to switch on and off the overdrive for engine braking??
example.. overtake ako, todo gas then pasok uli sa tamang lane then slowdown agad... turn off ko yung O/D.. ramdam na baba ng 3rd gear.... oks lang ba yun??
TIA
April 10th, 2005 10:14 PM #9
It is ok, but the effect will not be that much also. Better use your brakes for slowing down the vehicle. Brake pads are cheaper than if you mess up your tranny (e.g. O/D solenoid).
O/D off is for EXTENDED periods requiring engine braking.
April 11th, 2005 01:22 PM #10
yeah.. di nga din masyado.... naninibago lang kasi ako kasi first A/T ko to... di ako sanay na inaasa lahat sa brakes..
tnx for the info otep! tama, mahirap nang i risk pang masira ang tranny...
Ask ko lang naka by pass na ba Yan or servo pa din ang gamet mo
4g15 rare Idle motor (servo)
