Results 1 to 10 of 45
October 22nd, 2008 07:14 PM #1
mga kuya anu po ba dapat pag nag ddrive ng automatic car & van lagi ba dapat naka on ang over drive??
para saan ang hold button???
ngayon lang ulit kasi ako nakapag drive ng matic ,btw kia pregio ang van ko
October 22nd, 2008 07:32 PM #2
Overdrive allows the engine to run at a lower rpm for a given road speed, resulting in better fuel economy (ideal for cruising speeds). So whenever possible, engage overdrive when driving your A/T vehicle, except when overtaking, going uphill or downhill (engine braking) since OD mode reduces engine torque.
In manual transmission vehicles, the highest forward gear is the overdrive gear.Last edited by Bogeyman; October 22nd, 2008 at 08:23 PM.
October 22nd, 2008 07:44 PM #3
thanks sir btw: it means na mas makakatipid ako sa diesel pag laging naka over drive ang van ko?
October 22nd, 2008 08:18 PM #4
In normal driving conditions, makakatipid ka kung laging engaged ang O/D mo. However, you should still consult your owner's manual for the proper speed on which to run on overdrive.
October 22nd, 2008 08:35 PM #5
kung sa inyo po ano ba ang pwedng top speed for automatic O.D is ON sa kia pregio?
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 23rd, 2008 12:25 AM #6AFAIK, OD should be on all the time. Except as previously mentioned, overtaking, uphill and engine braking. It is the highest gear on your AT. I think the pregio is a 3 speed AT. OD is your 4th gear.
- Oct 2008
- 24
October 23rd, 2008 10:12 AM #7boss, matic din ang pregio ko acquire 2002 in signet, as advise and for more FC dapat palagi naka OD in normal road condition but if you will go uphill or down hill tsaka palang i-turn off ang OD.
October 23rd, 2008 10:31 AM #8
speedpedal ang overdrive ba ang pregio e yung power button,na pag naka on sya e me nakalagay sa dashboard na POWER malapit sa trashcan sa harap sa me bandang ibaba ng pihitan ng aircon???
October 23rd, 2008 10:33 AM #9
btw speedpedal 2001 din ang pregio ko aquire din sya ng 2002 festival sya white 2tone
kaso kabili ko lang sya this month pero ang lakas sa diesel 7 o 6km per litre ang kain?
mas matipid pa ang ginagamit ko na mb>>? wala pa ako masyadong lakad ittry ko ang OD lagi
kasi nagka pregio na kami dati blue 97 model pero ni minsan hindi namin pinakailaman yung OD BUTTON ,,
- Oct 2008
- 24
October 23rd, 2008 10:46 AM #10
yup. try mo din magpafull tank then tsaka mo ipower on then cruise ka lang sa city for an hour, dont forget to record the km then pa full tank ka ulit para mas maging acurate ang pagcomute ng fc. dapat nasa 9 to 10 km per liter yan kasi ang manual naman nakaka 12km per liter
Agree on the consistent implementation of traffic rules and regulations. By privatizing MMDA,...
SC (temporarily) stops NCAP
