Results 1 to 20 of 21
    Apr 2008
    Hi Guys,
    Just want to check what can cause a whining noise when my car is accelerating fron 1st to 2nd gear. Sounds similar when in reverse. No noise in neutral. Changed release bearing but noise is still present. Car is Honda City 2004 MT.
    Thanks!
    Jun 2016
    Quote Originally Posted by tonyboy View Post
    Hi Guys,
    Thanks!
    pressure plate sir nagpalit n po kayo?
    Jan 2009
    It's unlikely clutch-related. When was the M/T fluid last replaced? What is its condition and level?
    Changing the fluid, especially if it hasn't been replaced for a long time, should be the first thing to do. If the whine persists, it's very likely due to wear and tear. 1st and 2nd gear is the most used gears in a car that is frequently in stop and go traffic.
    Apr 2008
    Replaced the transmission fluid 3 weeks ago prior to replacing the release bearing and clutch disc.
    Jan 2009
    Prior to the oil change, walang whining noise whatsoever? If so, are you sure that the correct gear oil viscosity was used? Is the gear oil level correct?
    May 2009
    1st and 2nd gears share the same synchronizer hub/sleeve.....
    eto most likely ang may sira.....
    chipped teeth on the synchro hub, worn synchro,........
    bottomline, remove and disassemble the trans for better diagnosis.
    Apr 2008
    Quote Originally Posted by rileykyrra View Post
    Release bearing and clutch disc pa lang sir
    Hi Guys,
    Thanks!
    baka ang differential gear?
    Jan 2009
    If that were true, the whine would be present in all gears. 1st to 2nd gear lang daw eh.
    in truth, i am but guessing, because i have no idea what the sound is all about.
    baka iyong tensioner bearing ng drive belts niya? umiingay pag acceleration ?
    Apr 2008
    As per mechanic sir, ok naman daw since no noise naman when in neutral. May whine lang when accelerating. Hindi rin wheel bearing, no noise when coasting in neutral.
    Apr 2008
    Correct sir, on low gears lang especially when going uphill.
    Does the sound change with speed? Ugong sound? Or tick-tick sound? Sound changes with steering?
    Might be wheel bearing. Or it could be cv axle.
    CV Joint And CV Axle Problems - AutoZone Car Care - YouTube
    Apr 2006
    So far only on quick or sudden acceleration. Tnx.
    Jul 2017
    Hi Guys,
    Thanks!
    when engine is idling, is there a difference in the sound of the engine/transmission if you press your clutch?
    if yes and you already change/checked ur pilot bearing, clutch lining, pressure plate and the noise is still present, you need to change the main shaft bearing.
    when changing the mainshaft bearing, you need to check the roller bearings of ur 1st and 2nd gear, this is the prmary reason if you hear noises in a specific gears. sometimes the is like a crying baby,lol
Whining Noise
