does your transmission shift normally to all gears including overdrive? your system might have detected an out of range reading from the sensor/s.
is your vehicle equipped with throttle by wire accelerator?
areas to check: throttle position sensor, engine coolant temperature sensor and the vehicle speed sensor (VSS). your vehicle might have two VSSs. does your speedometer work properly?
