Results 1 to 5 of 5
- Dec 2008
- 7
February 15th, 2009 03:03 AM #1Good am... Help po naman..
Case: Lancer 1998 AT. unleaded gasoline 87,000km mileage
(1) Regular oil and filter change every 5000 km (Castrol, VIC oil filter)
(2) Fuel Filter - change at 73,000 km ( replaced using Maruzen brand)
change at 86,000 km - when checked kasi blackish na color fuel pag taktak nung filter)
(3) Timing belt/Tensioner Bearing changed at 85,000km , cleaned throttle body and servo
(4) ATF oil and filter changed at 74,000km (casa - they used 6 liters)
(5) Power steering fluid -haven't changed pa. - still pink in color, no burnt smell since acquiring the vehicle. Nung nagpapalit po ko ATF, sabi di pa naman daw po kailan palitan.
Problem po is:
Downshifting po from 4th to 3rd, once nasa 3rd gear, pag- apak sa gas may vibration po for a while, na parang kapos sa gas, nanginginig yung car, once na abot na nya speed for 4th gear ok na uli smooth na. Shifting from 1st to 2nd, may jerk pero minimal, then 3rd to 4th, smooth naman po. What causes po kaya yung nginig sa 3rd? Kailangan ko na po kaya uli papalit ATF. Na drain po din kaya yung ATF sa torque converter ng pa service sa casa?
Nabasa ko po sa forum na kailangan ng transtech machine to do that.. Wala po dito sa province ng ganoon. Balak ko po kasi di na sa casa dalhin kung kailangan palitan. May iba po bang paraan para ma drain yung fluid sa torque converter?
Tuwing kailan po ba nagpapalit ng power steering fluid?
Thank you po!
- Apr 2008
- 188
February 15th, 2009 03:41 AM #2ano na po ba ang quality ng ATF mo? sunog ba? but i don't think sa fluid ang problema mo eh since umaabot pa sa 4th gear... kumusta naman ang takbo when running in O/D?
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 15th, 2009 10:50 AM #3try doing a transtech type of procedure muna. it might help. it takes a lot of fluid though. expect to use at least 12 liters.
- Feb 2009
- 5
February 16th, 2009 07:14 PM #4hey bro.. minor lang yan, kung taga QC area ka pacheck mo sa JAZZ automatic transmission specialist in kamias. look for cris. ok kausap yun siya ung may ari dumerekta ka sa kanya.. pag ung mga boy/mechanic ksi nagmmarkup pa :-)
- Feb 2009
- 1
February 21st, 2009 01:47 AM #5thanks sa replies mga peeps! try ko change yung atf muna.. ok ba yung sa Jazz automatic transmission? di ba mahal sumungil? medyo malayo ako sa qc, bandang south ako eh, may lam kayo na magaling din sa AT bandang south? Laguna area po ako... TY
You just unregister the device where its currently installed.
National ID Law
