Results 1 to 6 of 6
    Oct 2005
    Please help...
    hehe Mazda boy na uli ako. Actually mag 4 months na. Me and sister both a 96 Mazda 323 Familia GLX AT last November.
    I love the engine and handling kaso nag-s-slide na ngayon yung transmission, runs out of steam in uphill to the point that i need to put on the hazzard lights. Put it to "N" then "D" para mag kind of reset yung tranny. Saka ko try to creep slowly to get to the top. Ubos na ata ang lining ng friction plate/pressure plate ko.
    Is there a shop na OK pagawaan at relatively inexpensive? Our mechanic cant do it kase kelangan pa ng machine na pang AT talaga para ma-test yung bomba/compression ng transmission eh. At saka totoo bang rebuilding kit lang ang talagang nabibili? walang pressure/friction plate na separate na mabibili. Im hesitant to go surlus kase.
    Mazda peeps please help naman. Thanks a lot. More power.
    -basti08
    check mo muna ATF level (nasa manual kung paano) before mo pagawa. Most of the time low ATF level is the reason why nag-sslide un transmission.
    Jan 2008
    if ok ang atf level mo, palitan mo na ng surplus yan transmission mo.. make sure you get transmission still attached to the engine.. also make sure the connectors are the same with the surplus.. do not swap the sensors or connectors from your defective transmission.. more or less 10k to 15k lang yan ok na
    Nov 2007
    10k to 15k for a surplus AT tranny? have been thru an AT problem before with our ford lynx 99 ghia,wherein we expiriencce the samething he expirience until it no longer works anymore and the hold indicator keeps blinking w/c means its not shifting anymore.,.,.puro high revs pag running and no response from the engine na,.,.,.,a shop nearby advice us that it cannot be repaired anymore.,.,.so they ordered the surplus tranny somewhere from north and it cost us 34k for the whole tranny itself,.,.including labor i think about 45-45k and guest what? the tranny is also a mazda considering that our car is a ford.,.,.
    Quote Originally Posted by tzulao View Post
    napamahal ka ata sir, sa mazdatech.org nasa 15-20k lang din ang quote nilang price for change ng automatic tranny.
    Nov 2007
    Quote Originally Posted by incus View Post
    is the mazdatech from banawe? surplus tranny ba ito? kasi considering were from batangas,..,we just let our trusted shop to do the ordering and syempre may transportation cost pa yun,.,.yung labor naman medyo napamahal kasi twicw ibinaba yung tranny dahil after makabit eh nagkaroon ng leaking so kelanagn ulitin ung job.,.,.but after that ok na ulit yung tanny namin
HELP Mazda peeps Familia AT sliding...
