Results 11 to 20 of 28
November 24th, 2002 10:15 AM #11Originally Posted by Dianne
- 197
November 25th, 2002 11:33 AM #12Kung hydraulic assisted ang clutch mo baka kailanagn mo na palitan yung fluid. After a while nagtutubig ang clutch fluid just like brake fluid eh.
- 109
November 25th, 2002 01:26 PM #13Mine is Adventure... so san ko siya lalagyan ng lubrication at paano? I've seen the cable from inside the car, its going upwards. Hindi ko masyado nacheck pero di ko pa nakita sa engine bay. puwede ko ba siyang lagyan without removing the cable?...
- 152
November 27th, 2002 07:19 PM #14pwede i adjust sa clutch pedal lang? masahdo mataas clutch ko e. wala bang maaapektuhan if DIY lang adjustment? :?:
November 28th, 2002 08:02 AM #15
Dianne::: is your adventure gas or diesel?
CoolGal:::Puwedeeee. it's either you adjust it , lalon tumaas or bumaba (hindi mo na shift)
- 152
November 28th, 2002 11:29 AM #16pano adjust? alin? yung sa clutch pedal o yung sa cable? iniikot lang?
- 109
November 28th, 2002 06:07 PM #17Originally Posted by afrasay
Gas... Super Sports... Di ko pa rin alam kung pano lagyan ng lubrication sa cable nor sa spring?... di ko makita kung san puwede...
- 237
December 11th, 2002 01:38 AM #18miss dianne
my dad also has an adventure...gls model...2002 model...
yeah...medyo matigas nga ung clutch ng adventure....di ata kasi hydraulic ung clutch nito....
December 11th, 2002 10:45 AM #19
sakin din ganito... :roll: 96 galant ss po
ganito din kaya remedyo or baka ubos na clutch fluid ko? :cry:
December 12th, 2002 04:48 AM #20
Defintely mas matigas ang clutch cable kaysa sa hydraulic type type (parang joke ito ha...). It a matter of observing the pedal pressure kung bumibigat kaysa sa dati.
high idle RPM at engine start
