Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    #21
    pano yun matigas yun clutch pedal ko e hydraulic un clutch ko. pressure plate ba prob?
    #22
    cable type nga siya... tried spraying with WD40... tigas talaga...wa epek...
    pano kaya mapalambot man lang maski konti... sabi kasi ng mechanic namin...
    yung adjustment daw ng clutch is only to make it higher or lower (the reaction
    against pedal pressure)... pero yung counter pressure ng cable sa apak mo
    (tigas or lambot) hindi raw na aadjust... comment please...
    #23
    help...
    #24
    Quote Originally Posted by CoolGal
    If super tigas, sa pressure plate na po iyan.
    #25
    Quote Originally Posted by Dianne
    Baka pressure plate na po yan. Try buying another cable (make it your reserve) and see if it solves the problem. Whats's your odo reading?
    #26
    bago lang Afrasay...less than 15K... just over 14 mos old...when I complained sa casa ganun daw talaga... shall I complain about the pressure plate?... wat d you think?... thank you ha...
    Dec 2002
    #27
    kung cable type baka hindi naka ayos mabuti(meaning naka pilpit or nababatak nang certain parts nung car mo) im not sure
    #28
    One question. Do you have another or a couple of other cars that you drive? If your answer is yes, then you might be comparing a car with a light clutch and a small engine to an AUV with a slightly heavier one with a bigger engine. Ask the casa mechanic to test drive your Mit. They will know. It's their product. Good luck. :wink:
matigas clutch pedal
