Results 1 to 9 of 9
- Dec 2006
- 42
April 30th, 2009 07:14 PM #1Good evening.
Bin seeking your help for quite some time now and I'm very thankful for all the help with my car.
But then again, just had my matic xmission replaced by a surplus one. It was running well during the past few days and I suddenly experienced jerks when I cold-start it. Meaning every morning, when I start the car and shift to Drive, it jerks like it's hard up to move forward. what I do is I shift it from P-N-D-2-L and wait a few minutes and I won't experience it the rest of the day. Nahihirapan umabante na parang naka-parking brake. Pero ung Reverse ok naman.
Please please help...again....
Thank you.
- Mar 2009
- 72
April 30th, 2009 11:44 PM #2Hi sir,
Experienced this also with my Subic Terrano na A/T. Ayaw umusad when cold start. In the end it will get worse and most likely your tranny might need another replacement.
Had mine converted to Manual in Banawe po para iwas ma uli with surplus one
May 1st, 2009 03:05 AM #3
Not enough info for what kind of vehicle.
If this is an electronically shifted transmission so the first thing I would do is pull codes out of the computer. There may be transmission codes in there even if the check engine light is off. Some shop will do that for free so get the codes and that wil help eliminate a few things. If one of the codes are maximum shift adapts you almost definitely will need to rebuild the tranny. I would not change the filter at this time if the fluid looks okay because for a car with that many miles on it sometimes it does more harm than good. Hopefully it is just something in the valve body like a shift solenoid but it sounds a little bit more serious than that.
May 1st, 2009 01:27 PM #4
have you drained and replaced the ATF? more often ito ang neglected fluid next to the diffs and brakes.
- Apr 2008
- 537
May 1st, 2009 03:12 PM #5mukhang ni-drained ang naunang ATF sa transmission mo pero ok lang yan kung halimbawang magandang ATF nailagay sa Automatic Tranny mo.
kadalasan ganyan ang nangyayari kapag bumili ka ng surplus na AT ang ginagawa ay dinedrain ang naunang ATF and then pinapalitan ng bago na madalas din nabibili mo ay peke kaya dapat hindi na idinededrain ang naunang fluid na nasa tranny na ilalagay sa'yo kaya dapat dinadagdagan na lang ito kung kulang.
magtanong tanong ka sa mapagkakatiwalaan mong kakilala, kaibigan na may alam sa kotse or mapagkakatiwalaan mong mekaniko kung ano ang magandang ATF
- Apr 2009
- 5
May 5th, 2009 10:22 PM #6sir san sa banawe mo pinaconvert to manual terrano mo? nd magkano nagastos mo lahat?
- Dec 2006
- 42
May 13th, 2009 07:38 PM #7Thanks for the reply.
Sir V6dreamer, any recommendations on where I could bring it for checking? Car is a 96 lancer glxi.
May 21st, 2009 09:50 AM #9
Imo at that price it becomes a very tempting buy even with its' flaws.
2021 Nissan Leaf
