Results 1 to 20 of 29
    Hi meron ako problem kasi tinakas ko car brother.
    4th gear sa flyover kahit press ko gas pedal ayaw na accelerate. Bagsak KPH, RPM normal lang not fluctuating. Meron din tumutunong sa front driver side parang sumasabit.
    Pag baba flyover shift sa primera and bigla ok naman at nawala yung sound sumasabit. Pero bigla hindi ulit accelerate and tutunog ulit. So i kept on trying moving the kambyo and ok ulit magaaccelerate hangang dahan dahan makauwi without being towed.
    I remember kaya hindi pala ginagamit ito car because ipapaayos yung leak sa transmission oil seal. Nasira ko kaya yung transmission nag leak lahat gear oil? Or symptoms of clutch disk and pressure plate?
    Aug 2010
    ask your bro, chances are... he know the answer to your question.
    I dont want him to know na tinakas ko.
    Baka kasi wala pa problem tapos lumala because of me.
    Ano most likely. If transmission ganito symptoms or pressure plate/clutch disk problem?
    In my opinion the best thing to do is to tell your brother. Hindi naman po sa pangingialam or pagiging KJ, liability mo yan kasi tinakas mo. Kung ako kapatid mo mas magagalit ako kung di mo aakuin ang kasalanan mo.
    Mar 2015
    Generally pag sira na yun tranny na manual uugong yan sir muna saka titigil or may mga gears na ayaw mag engage. May Ganun ba nangyari sir?
    Quote Originally Posted by SkyFlakes88 View Post
    Wala ugong. Pero nung time ayaw accelerate eh meron sumasabit sound front driver side. Pero pag nagaccelerate na wala sound. If ayaw accelerate balik ulit sabit sound.
    Nasa ibang bansa brother kaya hindi ko din masabi. Plan ko ipaayos para pagbalik nya doon ko lang sabihin after na maayos.
    I went pala sa talyer pero dahan dahan andar 1st to 2nd gear lang. Sabi mechanic clutch daw not transmission. Kailanga ko pa 2nd opinion para sure.
    sa clutch yan..... hindi nag eengage.
    so when are you going to tell the owner that there is something wrong with his car?
    if i were you, i'd confess to my deed, and volunteer to have it fixed, at my expense.. "kuya, hiniram ko kotse mo.. may sira pala.. kung ok sayo, ako na magpapagawa. but kuya, puede bang hiramin ulit kapag ayos na siya? i-full tank kupasya.."
    that should soften up brother's ire... , and teach me a lesson... that asking permission is cheaper than paying for what i probably did not initiate in the first place.
    but back to the problem..
    you said there was a leak.. i would suspect disk contamination by oil..
    also, baka may sira ang clutch assembly.. basag diaphragm spring.. friction pad too thin..
    whatever it is, it sure points to having to open the trans housing.
    Oct 2009
    may leak na daw ung tranny malamang nalagyan na ng gear oil ung clutch disc at pressure plate.or baka natanggal na rematche.ng clutch disc at un ung sumasabit sa flywheel.
    Jul 2014
    Let's stick and be firm with the the "tell your brother advice". That should teach the boy about respect and responsibility.
    Sep 2012
    Kung cv joint yan dapat may naririnig ka na Tok sound...
    Jun 2005
    nahuhugot pala ang cvjoint?
    mas duda pa ako sa diagnosis na cvjoint eh. mas feasible ang clutch problem.
    cv joint problem should not give you erratic symptoms dahil purely mechanical ito
    errr... what car are we talking about, po?
    CV joint..? why? the 3 talyers said transmission...
    Honda Civic VTI.
    The 3 talyer said sliding daw because of the whistling sound daw sa clutch.
    They tried the clutch test pero dapat if you release the clutch magmaintain na naka on engine if sliding. Pero nagoff eh.
    My brother told me na the whistling sound since 2010 pa.
    Quote Originally Posted by jodski View Post
    Oo meron tok tok tok sound. Nung hindi ako magaccelerate meron tok tok tapos pag nakaaccelerate nawawala tok tok sound.
    Quote Originally Posted by sirkosero View Post
    Doon sa fourth talyer kasi sanay sa honda cars kaya pinuntahan ko. Sinasabi ko pa lang symptoms eh sabi ng mechanic "driveshaft daw" kaya nashock din ako kasi not the usual sliding na clutch. He repeated if meron tumutunog sabi ko meron pag hindi makaaccelerate pero nawawala if nakaaccelerate
    Nahuhugot daw yung bearing ata sa driveshaft kaya parang "sliding"
    Meron ako nakausap 5th talyer and confirmed the 4th talyer diagnosis pero kailangan nya makita dalhin ko later.
    By the way so far hindi pa bumabalik yung hindi mag-accelerate. Dahan dahan pag gamit ko steering.
    Ito kausap ko brother. Year 2005 napalitan daw replacement sa banawe cv joint plus cv boot. Not the buong assembly drive shafts.
    The 4th talyer explained to me na dahil replacement type na daw driveshaft kaya ganyan.
    Jun 2005
    kung 99.98% sure, go for it. let us know kung eto nga talaga. wag mo isabay pagawa yung iba para ma-eliminate mo. snap us a photo of the cv joint too.
    May 2009
    asa ka pa sa mekaniko. malamang gagawin ang "shotgun approach" para lumobo yung kita. hihihi
Manual Transmission Problem
