Results 21 to 30 of 39
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 1st, 2006 06:51 PM #21dextron3 is backwards compatible with other dextron types.
gear ff is for lsd equipped transmission. kung hindi naka lsd yan just use gear 300.
- Sep 2006
- 110
October 23rd, 2006 06:26 PM #23
correct me if i 'm wrong pero ang lsd o limited slip differential kasi is kapag naka-lift parehas ang both drive wheels, kapag inikot mo yung isa sa isang direction, sabay yung kabilang gulong. unlike sa hindi limited slip differential na kapag inikot mo yung isang gulong sa isang direction, yung kabilang gulong baliktad sa ikot nang pinapa-ikot mong gulong.
October 23rd, 2006 11:55 PM #24
Tama is sir ian_rex.
LSD is a traction aiding device. Unless your model had an LSD equipped variant, chances are you have a [conventional] open diff.
October 24th, 2006 01:23 AM #25
mga ilang liters and manual transmission oil for a 97 cefiro? i want to try motul. any feedbacks about this gear oil?
- Nov 2003
- 3,849
October 24th, 2006 08:55 AM #26about 2.5-3 liters of the gear oil for the cefiro. i assume it's manual right?
October 24th, 2006 02:14 PM #27
- Nov 2003
- 3,849
October 24th, 2006 09:05 PM #28a member of tsikot loaded up with motul gear 300 kanina on his galant. let's wait for his feedback
- Sep 2006
- 110
October 25th, 2006 10:06 PM #29tnx. tnx.
ok ba 2?
[SIZE=1][/SIZE] [SIZE=1][/SIZE] [SIZE=1]
[/SIZE] [SIZE=1][/SIZE] [SIZE=1][/SIZE] [SIZE=1][/SIZE]
ang nakalagay sa manual ay API GL-4, SAE 75W/85w
ano ibig sabihin ng sae 75w/85w?
tia po.
- Nov 2003
- 3,849
October 26th, 2006 11:25 PM #30that's the viscosity. gear 300 is 75w90 tho but it should do the trick naman.
Bigat paa :grin:
(2023) Ford Territory
