Results 11 to 14 of 14
August 6th, 2017 09:52 AM #11
Maybe it's not the transmission but your engine idle rev that needs to be checked ...
- Oct 2015
- 99
August 7th, 2017 01:09 AM #12Engine rev is stable at around 750 rpm.
August 7th, 2017 02:06 PM #13
check the propeller shaft esp the joints, transmission support, differential backlash. also fluid level.
- Oct 2015
- 99
August 12th, 2017 10:28 AM #14Will check them next. Balitaan ko po kayo. Feeling ko transmission support.
Pero nun nag flush atf check din nila and sabi nila ok naman daw.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
