Results 1 to 14 of 14
    Oct 2015
    Hi
    Ask ko po. After mag dialysis ng atf malakas na pag jerk ng car pag neutral or park to drive.
    Ginamit ko is mag 1.
    baka wrong atf? what vehicle?
    Oct 2015
    Toyota innova.
    Sa likod ng mag 1 nakalagay sa likod "additionally recomended for toyota type T, type iii, and type iv"
    yan ayaw ko sa dialysis. meron contaminants. drain fill will have less contaminants. ano na nasa odo? 40k? did you change the atf because it was jerking?
    Oct 2015
    Lakas ng sipa from neutral to drive.
    Naka step ako sa brakes and shift it to drive. You really feel the car wants to move forward.
    80tk na takbo. Pinacheck ko yung atf sabi it is very dark na. Kaya pinapalitan.
    much better pa ba mag drain vs. dialysis bro?
    ano ba difference nila? e.g. 3x drain atf within a month or 2 VS dialysis one time?
    Quote Originally Posted by dieselpowah View Post
    so you replaced the atf because of symptoms? dapat regular maintenance every 2yrs or 40k...toyota type3 isnt fully syntethic..hindi tumatagal.
    80k? first atf change?
    drain and refill lng pwede na. 3x drain and fill? 2x pwede na. makikita naman kung malinis na yun lumalabas.
    Oct 2015
    Wala naman symptoms. The mechanic pointed out na the atf fluid is dark and need replacement.
    Before that dialysis wala problem yung car.
    Btw. Pag nag drive na it is smooth di maramdaman yung shifting. Only problem is the initial engaging to drive. Sipa talga. Like someone rear ended you.
    Oct 2015
    80t kms was the first change.
    Meron pa isang car nasa 90t+ kms. Never pa napalitan ng atf.
    Ngayon nag dadalawang isip ako kung papa dialysis ren.
    Mar 2004
    Maybe it's not the transmission but your engine idle rev that needs to be checked ...
    Oct 2015
    Engine rev is stable at around 750 rpm.
    check the propeller shaft esp the joints, transmission support, differential backlash. also fluid level.
    Oct 2015
    Will check them next. Balitaan ko po kayo. Feeling ko transmission support.
    Pero nun nag flush atf check din nila and sabi nila ok naman daw.
Jerking when put into drive
