help
toyota 4runner , start pero ayaw andar.....or drive forward even reverse
1994 toyota 4runner automatic
as ive read , revving it up while in P =park will damage my transmission
please ....
help
please ....
Are you saying it starts but won't move in either reverse or drive? In my experience when the A/T begins to break because of wear and tear it will still move in one of the other gears, i.e. you will lose reverse but still have a somewhat functional forward gear, it doesn't just break without warning unless it was completely abused.
Originally Posted by redorange
yes , starts but doesnt move , either reverse or drive
Originally Posted by afrasay
can speedyfix do home service ? kasi ayaw nga andar he he he
thanks boss
How's your ATF level? Though, it would maybe be either extremely low or empty to have the symptoms you are mentioning.
Originally Posted by Autobeat
ATF Level is fine naman
thanks for your replies , hoping i can save my transmission
Subukan mong ireset ang computer. Disconnect mo ang battery terminals,after 10 mins. ireconnect mo.
Originally Posted by ciagar11
sorry , eng eng pa aku ...panu ku re set computer box , thanks
What year is the 4runner? I assume it's not a local version since I don't think it was sold in the Philippines. If it's a US version you may have engaged the shift lock release, check your manual to see how it works. What color is the ATF? Do you have a burning or rancid smell coming from the hood or near your transmission? Is it or was it hard to move the shift lever from P-R-N-D? Have you tried putting it in 2 and 1 to see if it will move?Originally Posted by lazaro
Before it's current state did you come to a full stop before shifting the transmission? Have you ever used it like a manual transmission, i.e. shift down to engine brake? If you answer yes to the burning smell, hard shift and the last two questions then your tranny may be fried.
ATF -------sir mamu mula pa ..
shift lock release------hindi ku alam san sir , alang manual
i tried it in L and 2 ----------negative pa rin
thank you sir for your time ....
SHIFTING --------not that hard sir
Toyota 4runner ------ 1994 ,
SHIFTING - sir minsan nga shift ku lang pagalis ---from PARK to D
tapus MINSAN pag trapik --------D to N
paguwi ----------------D to Park
maybe the linkage (if equipped) to the selector, try mo engine off move the selector and let someone see below or open the tranny hump if the selector makes the linkage (if eqipped) is also moving.
as they say if the tranny is broken there should be movement somehow, but may be slow but there must be movement.
Originally Posted by ARB
Thanks for all the replies , ill try it one by one and hoping hindi kayu magsawa sa advice
wish i will not change my tranny
You shouldn't need a new tranny, you can get a master repair kit which will replace the friction & steel clutch plate, gaskets & seals, o-rings & sealing rings. I just checked the net and it goes for about $170 for the kit. Another thing you may want to check is the transmission control solenoid. Unfortunately I can't find any service bulletins for the tranny of your truck only the power steering recall.Originally Posted by lazaro
