Iba po bang radiator cap ginagamit for a/t and m/t? I just called el dorado and they told me magkaiba daw. Is this true?
baka mag ka iba lang ng pressure settings.. pero pwede naman gamitin ang pang A/T sa Manual basta same size lang.. pareho din naman ng principle yon
Pajero JDM po sir. Nalalabuan din nga ako eh. Ano naman po yung radiator cap na may spring sa loob kc nakakita po ako sa isang shop. tnx
its either big or small..the common ones are either 0.9 or 1.1 pressure..meron din higher than 1.1
wanna have ko is the 1.1 up..tried .9 on y liteace, early ang release ng pressure,e...
it should be ok pero if you have problems with the cooling system of your car then using a higher pressure cap will just make things worse.
I see I think Ill stick with 0.9 na lang. whats the difference naman ng radiator cap na may spring and wala? gamit ko kasi is circuit brand, baka pangit tong nabili ko.
wala pa akong na encounter na radiator cap na walang spring sa loob...mas malakas ang pressure ng 1.1 kesa 0.9...un lang ang difference nun. kapag luma na radiator mo at pangit cooling system, baka magburst ang radiator kapag 1.1 ang gamit mo.Originally Posted by kakabakaba_kaba
*psi ang unit nun db?
