had the same problem... had a leaking atf... had inquire sa mga semi cas around lowest 5k gastos for the reseal ng gasket and oil seal... la pa budget kaya alagaan ko na lang muna sa at fluid... wag lang matuyuan ok pa yan everyday check your atf level... tas after every ride....check ule...
pero kung malakas na talaag tagas... no choice ka n nyan bro... soon ipapaayos ko na din to... ipon mode muna
