Page 1 of 2 12 LastLast
Results 1 to 10 of 34
    Jan 2008
    Lately, bigla nagloloko starting ng automatic
    transmission car namin. After turning off engine
    or parking it less than about 30 minutes, then
    pag-start mo...ayaw start........Then pag-ginalaw namin
    shifting gear up and down.....then start mo ulit...mag-start
    na engine.....Last few days, we have to do it about 5 times
    before it starts.....Pag park naman namin ng matagal...one click
    lang start na..........By the way our car is Nissan March 2002
    Model..Its battery is still new......Hope you can help us guys...
    Thank you and Happy New Year to all!!!!!
    Chris
    Sep 2004
    Top of mind ko, starter solenoid. Pwede rin carbon brush ng starter or starter mismo.
    Happened to me once also, turned out starter solenoid lang pala.
    Hello,
    It has nothing to do with the transmission, my Alty was like that before too, the prob is your starter... AT requires a bit more juice for it to start properly, unlike in MT. Battery and starter has to be in tip top shape.
    Yup, happened to our office's Suzuki APV AT. Starter solenoid dumikit. Baka pwede pa namang madala sa linis.
    Jul 2006
    If you move the shift lever and it starts after you do that, it's the neutral safety switch - responsible for turning on the reverse lights, allowing the ignition to only start in neutral (N) or park (P) only.
    May 2007
    as you said ng ginalaw mo yung shifting stick up and down, probably yung safety switch nga ang sira. automatic transmission will start only on park position, others pwede rin sa neutral.
    Quote Originally Posted by chrismartin View Post
    Chris
    nagawa na ba car mo ? and what was the real culprit ? is it the starter solenoid ? same problem kasi with my mazda 323 automatic, ayaw din mag-start...
    Katulad ng sinabi ko '98 gli AT ang gamit ko battery at mga fuse at sparkplugs ang madalas kong palitan 180k na ang tinakbo ko okey pa rin sya ngayun.
    same problem here, at pareho din tayo ng ginagawa para umandar yung oto (shift up and down yung gear then start again). nitong monday lang pinacheck ko na yung starter ko, para ngang walang diperensiya nung tinest yung starter, pero nung inobserbahang mabuti mahina na daw palo nung solanoid niya. nilinis lang yung solanoid, ngayun ok na pag start.
    Oct 2004
    yan din ang problema ko dun sa dating 94 corolla gli a/t ko. pag sa umaga one click lang, pero once mainit na makina o after a trip pag pinatay ko makina then start again ayaw na.not even a single crank. kailangan ko pa hintayin a few minutes para mapa start uli. dati ginagalaw ko yung shifter from park to drive pabalik balik and it helps, pero katagalan hindi narin effective strategy ito. Napansin ko rin na parating pumuputok ang fuse niya. Hindi ko na nalaman papano naging resulta kasi binenta ko na yung sasakyan (nangyari pala ito after malubog sa baha yung kotse).hanggang wheel hubs kasi yung baha
Help...Help...Ayaw mag-start: Automatic Transmission Car
