Results 11 to 18 of 18
- Dec 2004
- 47
May 18th, 2005 03:47 AM #11baka me diperensya na ung mga differential gears nya.
check mo gears oil nya.
June 25th, 2009 09:57 AM #12
I have this problem with my Crosswind, before i dont have this but right there's a grinding sound when you shift to reverse it is hard to engaged in reverse.. I'm afraid I might damage the transmission.. in 1st gear i dont have this problem only in reverse.
June 26th, 2009 06:37 AM #14
June 26th, 2009 08:27 AM #15
June 26th, 2009 04:48 PM #16
also, check the engine mounts specially the torque reaction strut (dogbone) usually installed at the north of the engine (12 o'clock position) compartment between the radiator frame and the cylinder head. the shifter arm on top of the transmission will engage but sometimes slightly pull out of gear. remember, your honda is oriented west-east (engine at nine o'clock and transmission at three o'clock) and the torque reaction is to pull away from the firewall on reverse.
jick
- Oct 2009
- 6
October 15th, 2009 11:26 PM #17same problem with my car. nagpalit na ako clutch master pero the problem still exist. kaya baka something wrong sa shifter linkage bushings.
October 20th, 2009 03:16 PM #18
Ako naman, just recently change my Clutch Disc, pressure plate and Release bearing. Hard shifting na kasi and me pagka sliding na. I have a 96 Corolla Gli. After the work, I did notice na medyo tricky yung reverse nya. Initial gamit ko after the work, grabe grinding ng reverse, parang truck. Then after a few driving, nahuli ko na kiliti. Need talagang isagad yung apak sa clutch para maging smooth ng reverse shift. Kaya lang medyo annoying kasi talagang tataymingan mo para walang grind.
Oks lang po ba yung sagarang apak sa clutch. Should this be the reaction even new yung clutch system ko??
Salamat sa mga magrereply...
