Results 1 to 12 of 12
    Oct 2009
    thanks sir jick.cejoco
    car ko is 1993 corolla gli. saan po attached yung backlash? pwede ba idismantle yung diff. gear then adjust?
    thanks again...
    Aug 2004
    For a front-driver with a stock open diff? Not really.
    If you haven't replaced your CV Joints, just replace them... it's more likely those than your differential.
    How loose are the CV Joints, and where? Between the axle and the CV, or between the CV and the differential housing?
    Oct 2009
    I already replaced both inner CV joints sir. The loose between the inner CV joint and differential is about 3mm radial play.
    Thanks
    Aug 2004
    Time to replace that differential, then... are you sure you got the right size of CV Joints?
    Oct 2009
    yes sir i got the right size of CV Joint. Thanks to all.
    Mar 2007
    How much are differentials? What about LSDs for toyotas? Where do you buy them? Can i choose the gearing? Hope to hear from you. thanks
    Feb 2009
    Quote Originally Posted by oceanrider88 View Post
    lsd for toyota are commonly found on supras of the eighties. there are aftermarket diffs available with different gearings. you can find them in imports magazines
differential gears
