Hello mga Gurus,
May I know kung narerepair ba ang differential gear. Malaki kasi play ng inner cv joints ko. Kaya I suspect na differential gear ang problem.
Thanks in advance...
Hello mga Gurus,
deval,
your diffs can be adjusted for contact depth, tooth contact pattern and backlash. the pinion or drive gear can be adjusted fore or aft in relation to the vehicle position, the side gear or driven gear or ring gear can be adjusted crosswise of the longitude of the vehicle. if you are talking about "play", you might be referring to the backlash. this can be adjusted too.
jick
thanks sir jick.cejoco
car ko is 1993 corolla gli. saan po attached yung backlash? pwede ba idismantle yung diff. gear then adjust?
thanks again...
For a front-driver with a stock open diff? Not really.
If you haven't replaced your CV Joints, just replace them... it's more likely those than your differential.
How loose are the CV Joints, and where? Between the axle and the CV, or between the CV and the differential housing?
I already replaced both inner CV joints sir. The loose between the inner CV joint and differential is about 3mm radial play.
Thanks
Time to replace that differential, then... are you sure you got the right size of CV Joints?
How much are differentials? What about LSDs for toyotas? Where do you buy them? Can i choose the gearing? Hope to hear from you. thanks
For the Corolla 4AFE, I don't know of any LSDs you can get. There is one available for the 4AGE, came with the 6 speed unit for the Levin. But I don't know if the box will bolt up to the engine or if the differential will fit in the 4AFE box.
Thanks jick. Will a supra diff fit a front wheel drive 5s-fe automatic tranny? I am hoping to get a 3.944 or 4.13 gear ratio. What would yo recommend for a 2.2 engine if i am looking for fuel economy?
Thanks niky. My differentials are actually shot up so i was thinking of an LSD as i really have to change mine anyway. Could you give me options for differential swaps? would a 3s-fe or 4a-ge differential fit my tranny?
Hope to hear from you. Thanks.
oceanrider,
i apologize for the confusion. the supra diff was just used for an example and is of ring and pinion type differential, the 5SFE or 3SFE or te 4AGE transaxles are those of helical drive gear type. the supra diff does not fit the FF (front engine/ front wheel drive) layout
jick
