Results 1 to 10 of 24
- Mar 2007
- 69
April 10th, 2007 07:44 PM #1anybody have any idea about the maintenance scheme of the cvt transmission? any cons about this transmission?
anyone? pleeeease?
thanks experts...
April 10th, 2007 07:46 PM #2
Well... nobody's replaced one yet, so we're not sure... but if you drive hard enough, you might be able to find out...
April 10th, 2007 11:26 PM #3
Just regular fluid changes like in a conventional geared A/T or M/T.
Make sure you use the correct fluid (check your owner's manual).
It's when you blow one up that makes things expensive. So take good care of it.
- Mar 2007
- 69
April 11th, 2007 01:37 PM #4cvt is belt driven right? so pano maintenance ng belt? do you have to change it every so-so number of kms? iniicp ko lang kc, ung belts kc high wear n tear yun e. pano ba?
April 11th, 2007 02:14 PM #5
Yeah, but the belt is made from steel. I don't think it ever needs replacing.
EDIT: Depending on the model, it may also have a high density rubber belt. These need replacement when they start to slip.
April 21st, 2007 09:52 PM #6
A couple of weeks ago, Honda Alabang called me up to "upgrade the CVT fluid free of charge" for our Jazz which we bought Oct., 2004. According to them, it's their branch's project and will take only 2 hours.
Has anyone been called-in by their casa for this CVT fluid upgrade?
I surmised they called me because I have not been bringing the car for their PMS. Else it would have been a part of their regular PMS. The last time I brought the car to Honda Alabang for the 10T Km PMS was approx 6 months ago. The car has only 11.7T Km logged as of this time.....
2501:showoff:
- Feb 2007
- 14
May 2nd, 2007 12:24 AM #7ask lang po bakit yung sa city pag unang andar may parang dumudulas ung transmission belt niya anu po ba problema? parang po nanginginit ung kotse.. CVT na 1.3
May 2nd, 2007 09:37 AM #8
I had problems with my battery a year ago and had it replaced sa casa. They told me that they need to change the ATF of my CVT and it will be done for free.
I bought my Jazz 1.3 CVT in March 2005 and i'm driving it really hard. So far so good naman sya.
- Jul 2009
- 2,618
January 10th, 2020 09:03 PM #9Good evening!
ang honda cvtf ay superseeded lang ng hcf2 or hindi talaga sila interchangeable?
thanks
also found hyundai xteer cvt. 1.5k lang. 4L claims na compatible with honda hcf2.
January 10th, 2020 09:11 PM #10
according to motul even the old non-earth dreams cvt will accept the multi-cvt fluid they have. as well as the current gen city and civic. i'm guessing the viscosity is almost the same. I think the xteer cvt should be ok.
https://shopee.ph/(NEW)-XTEER-ATF-CV...035.2511626383
I can't quite see the specs but i think this is the same 4L you're eyeing.
Roadstar is reliable.
Finding the Best Tire for You
