Results 1 to 7 of 7
- Apr 2009
- 3
April 19th, 2009 08:54 PM #1hi der tsikoteers
a newbie here needs ur help
gear shifting is hard
whenever i dont use my car for several days(stock for 2 or more days)
i have to pump the the clutch pedal several times to get into shifting
my ride
ae90 corolla small body
2e engine
never had my clutch checked since i got it
hope to hear from the group
TIA
April 19th, 2009 09:50 PM #2
knocturne in e flat,
sounds like hydraulic problem. no friction problem? ae90 seems to have aged. the master cylinder might need to be refurbished wirha new kit. check if the clutch master cylinder bore is not scored, nicked, scratched, corroded or pitted. if the bore looks ok, just repair it with a kit. while you do that, do the slave cylinder too. they were installed the same time, same mileage, same contaminated fluid they were exposed to. save the trouble, uyou're gonna have to bleed it anyway, Might As Well(MAW) do the whole operation or risk being stuck on the road as a hazard to other motorists. and for sure is not very convenient for you specially you're suck in traffic or need to use the bathroom bad.
jick
- Apr 2009
- 3
April 19th, 2009 10:22 PM #3thanks
so i just have to buy a repair kit
what specifically i would say at the shop??
pcencia na po newbie tlaga sa parts
ito po ba yung cylinder sa lgayan ng break fluid or clutch reservoir???
isa lang po ba repaiir kit nito???
things i should do???
parts and labor cost???
thanks ulit!!!
April 20th, 2009 05:19 AM #4
- Aug 2004
- 164
April 20th, 2009 10:54 AM #5
1. Check fluid level in clutch fluid reservoir and fill to correct level.
2. take car to your mechanic and explain the problem
He should inspect your clutch system i.e. clutch master cylinder and plumbing for problems.
Ask him for his diagnosis.
Go from there.
If you want, you may share with us his diagnosis.
April 20th, 2009 05:24 PM #6
sounds like a hydraulic problem alright. have a machanic check for leaks if you dont know where to look for them.
