Results 1 to 7 of 7
    Apr 2009
    hi der tsikoteers
    a newbie here needs ur help
    gear shifting is hard
    whenever i dont use my car for several days(stock for 2 or more days)
    i have to pump the the clutch pedal several times to get into shifting
    my ride
    ae90 corolla small body
    2e engine
    never had my clutch checked since i got it
    hope to hear from the group
    TIA
    Feb 2009
    Quote Originally Posted by knocturnal84 View Post
    hi der tsikoteers
    my ride
    2e engine
    TIA
    knocturne in e flat,
    sounds like hydraulic problem. no friction problem? ae90 seems to have aged. the master cylinder might need to be refurbished wirha new kit. check if the clutch master cylinder bore is not scored, nicked, scratched, corroded or pitted. if the bore looks ok, just repair it with a kit. while you do that, do the slave cylinder too. they were installed the same time, same mileage, same contaminated fluid they were exposed to. save the trouble, uyou're gonna have to bleed it anyway, Might As Well(MAW) do the whole operation or risk being stuck on the road as a hazard to other motorists. and for sure is not very convenient for you specially you're suck in traffic or need to use the bathroom bad.
    jick
    Apr 2009
    thanks
    so i just have to buy a repair kit
    what specifically i would say at the shop??
    pcencia na po newbie tlaga sa parts
    ito po ba yung cylinder sa lgayan ng break fluid or clutch reservoir???
    isa lang po ba repaiir kit nito???
    things i should do???
    parts and labor cost???
    thanks ulit!!!
    Feb 2009
    thanks
    thanks ulit!!!
    i apologize, i do not know how much it cost for parts or labor cost. the professional time on it including bleeding the system for both the master and slave cylinder is about 1.2 hours
    jick
    Aug 2004
    thanks
    thanks ulit!!!
    1. Check fluid level in clutch fluid reservoir and fill to correct level.
    2. take car to your mechanic and explain the problem
    He should inspect your clutch system i.e. clutch master cylinder and plumbing for problems.
    Ask him for his diagnosis.
    Go from there.
    If you want, you may share with us his diagnosis.
    sounds like a hydraulic problem alright. have a machanic check for leaks if you dont know where to look for them.
    Oct 2008
    adjust clutch freeplay..
clutch problem from a newbie
