Quote Originally Posted by v6dreamer View Post
YOU SOLVED THE PROBLEM! WD40 is only a temporary lube, and since after you spray some lube on the pivot point of the pedal and the squeak stopped, you figured the problem out. It (the pivot point of the pedal) needs to be cleaned and greased. Done deal. Good job on saving yourself a lot of money!
He half-way solved noise no. 2.
Noise no. 1 is still there.
