Results 51 to 60 of 72
September 5th, 2006 09:45 AM #51
September 5th, 2006 10:06 AM #52
AFAIK orig yan FCC brand pati yung release bearing kase almost same price sa casa. Mas mura dyan kung replacement parts. Last March lang ako nagpapalit sliding na din kase.
94 Civic yung kotse ko so more or less e same price lang naman siguro sayo.
Sa Speedyfix ako nagpapaservice. Contact mo na lang si Migs dun sa sig nya
- Nov 2006
- 132
December 14th, 2006 09:31 PM #53Guys, clutch din ba ang culprit kung hirap sa akyatan ang liteace. Hirap kasi lalo na kapag paahon kahit ako lang ang sakay. Madalas naka 2nd gear lang ako sa liteace when my VTI can climb at 4th gear. Mga half kilometer slope na siguro 15 degrees inclination lang. Hahit na nakabualo na ako sa 3rd gear, sa kalagitnaan slowdown na ako sa 2nd gear. Sa patag wala namang problem kahit na full load. What seems to be the problem?
December 15th, 2006 10:23 AM #54
I also have a related problem..pansin ko hirap ang makina pag akyatan first gear na parang nag vi vibrate yung manibela tapos biglang hahatak at hihina muli. This is especially true in first gear. It also happens in 2nd gear pero pag medyo mataas na rpm. May nararamdaman din akong vibration sa kambyo lalo na pag mababa ang gear. Sabi naman nila baka yung pressure plate ang me problema.. nag pa estimate na rin ako ng buong clutch kasi pag papalitan daw pressure plate, kelangan na rin palitan yung disk, bearing, etc para minsanan ang babaan... thanks in advance sa advise mga fellow tsikoters!!
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 20th, 2006 09:40 AM #55prices of parts and labor will differ from car to car depending on how involved the work is to pull down the transmission.
January 15th, 2007 01:06 PM #56
pabuhay ng thread..
immha ving the same problem right now...
"3) Release/Tension Bearing - release bearing lang po. Tensioner bearing is for the timing belt and in some cars for the fan/ac/alt belt. To test the release bearing put the shifter in the neutral position and listen. If you hear a whinning or humming sound and it disappears when you step on the clutch medyo may tama na ang bearing mo. But this doesn't mean sira na yun. It could take years bago tuluyan bumigay yun."
ganito yung problem ng adventure ko.. bumili ako ng parts sa La Brava, tapat ng ATco. twice na kmi nag palit ng release bearing pero same output.. nandun pa din yung sound.. may suggestion po ba kayo?
February 18th, 2007 10:59 AM #57
pabuhay po ng thread:
ask ko lang po sa #1 - naexperience na po namen yung sliding (mahina hatak, pero lakas RPM) sabi nung mekaniko ng bayaw ko papalitan na daw ng whole assembly (clutch)
gusto ko lang po marinig opinion nyo kung whole clutch na ba talaga?
ndi pa kasi ako nakakabalik kina speedy para pa check up.
anu kaya possible na sira dito? and replacements?
thanks po
February 18th, 2007 11:28 AM #58
malamang sliding clutch ka na nga
di naman sabay sabay nasisira lahat ng parts ng clutch assembly
(pressure plate,release bearing ,clutch disc ) sa Manual tranny
kaya lang kasi lahat pinapalitan na ,kasi para isang gawaan na lang or isang babaan na lang ng transmission mo at least nakatipid ka pa sa service charge
- Nov 2003
- 3,849
February 20th, 2007 10:58 AM #60
chief speedy
eto po yung observations ko (after using last monday)
kasi before mga 2 weeks ako habang ng ccheck ako ng battery,
nakita yung air take tube nya merong crack, so nilagyan ko ng tape
para sarado na, ok naman yung takbo nya
then nung lingo sabi ng bayaw ko, nag slide na daw yung cluch,
which is naramdaman ko rin talagang 4k rpm 1st gear - 2nd gear 20kph
ang bagal alang hatak.
pero nung monday morning bago ako punta office iniisip ko kung yung
tape na nilagay ko yung problema. kaya tinanggal ko yung tape na nakabalot dun sa air intake tube. then after that nag ok na yung hatak nya 2k-2.5k rpm
Hybrid is the way to go. So you don't rely heavily on the batteries.
Hybrids and EV
