Results 1 to 15 of 15
    Aug 2003
    guys i need your inputs on this... my car as reflected sa profile ko is a 95 corolla.
    meron long time problem yung clutch ko. before napalitan ko ng 2 replacement and 1 original. napalitan na din yung secondary assembly.
    a few months lang yung tinatagal ng replacement pati nung 1 original na pinalit ko. sa lahat ng parts na pinalit din (kasama original) nagkukulay black yung fluid reservoir. and nung last na palit meron konti oil residue na kasama sa fluid. di ko alam kung paano nasamahan since wala naman di ba ibang parts na nakakabit sa transmission system.
    opinion ng mechanic na kausap ko buksan daw yung transmission baka andun yung problema kasi pati yung original nasira agad.
    yung first replacement na kinabit ko pala lasted more than a year. and habang tumatagal paikli ng paikli yung lifespan ng assembly. di ko nga din maintindihan bakit pati yung original nasira agad.
    any opinions? ano kaya problema sa system? parts? mechanic?
    or owner?
    Mar 2005
    are you sure your clutch line doesn't go anywhere else
    Aug 2003
    eheheheheh. wala naman po ibang pinupuntahan yung linya.
    Jun 2005
    Quote Originally Posted by roninblade View Post
    ganyan din ang sa pick-up ko. hindi ko alam kung bakit. kahit bagong palit lang ng fluid, a few days lang itim na...
    Aug 2003
    well, i know why it does that. ang problem ko is baket pati yung original toyota part ganun nangyari sa akin and in just a few months at that.
    btw, galing yung black color is caused by the rubber sa loob ng clutch master assembly.
    Nov 2003
    check if everything is aligned correctly. baka may kayod yung pedal kaya lagi nasisira agad.
    Buong clutch master assy po ba ang pinalitan or Piston lang? Kasi kung piston lang ang pinalitan malamang sira na yung clutch master cylinder magaspang na yung loob or matalas kaya nasisira kaagad yung seal kaya nangingitim yung fluid.
    Aug 2003
    whole assembly yung pinalitan.
    nag-bleed ba ng fluid after mapalitan yung clutch master assembly para malinis yung buong system? tapos orig ba kaya talaga yung ipinalit? marami na kasing nagkalat na orig "kuno" na toyota parts gayang-gaya yung packaging.
    Wow nasira kaagad? Nung binili ba yung pyesa nasa loob na ng cylinder yung piston? as in whole package yung dating?
    Aug 2003
    i just bought a new assy yesterday; galing casa na talaga para walang duda. pina-flush ko din talaga ng maayos yung line; and wala naman kami nakita misalignment sa pedals (as suggested by sir speedyfix).
    tignan ko kung ano mangyayari.
    actually, in a month papagawa ko din yung clutch disc, pressure plate, and release bearing. tingin ko wala naman connection dun yung problem ko sa assembly. tama ba? or pwede din ba mag-leak ng engine oil to the clutch assembly pag worn na yung transmission parts?
    Walang kinalaman yun sa Clutch Master malayo sila mag-connect ng fluids kasi isa lang naman pupuntahan ng Master yung secondary na piston para lang ma push niya yung clutch disc. Anyway roninblade pag iinstall yung Clutch Master Assy. dapat wag mo munang patapakin yung clutch or bombahin yung clutch habang wala pang fluid yung reservoir ng clutch master kung hindi masisira kaagad yung seal nung piston. Sana after niyang Original na Assy. Tumagal na siya Good Luck Roninblade.
    Nov 2003
    goodluck! hope everything works out na!
    Aug 2003
    thanks guys. tumagal na sana yung part.
    Aug 2015
    Mga boss anu magandang replacement brand para sa clutch master at slave cylinder? Ok ba ung seyken/seiken? Thanks.
    2000 civic
