Results 21 to 30 of 51
November 1st, 2003 04:59 PM #21Originally posted by Paulo
[B]furthermore, here are my concerns on using the clutch...
#1) Let's say, your car is parked at the basement, for example, in Robinson Galleria basement parking...
As soon as you pay your parking fee....you are faced with a Long Deep inclined road way up...
If your driving your car, what do you do?
---coming from full stop, naka hand break... timplahin ko ng konti yung clutch.. para umusog ng konti. tapos bitaw ng handbreak... press on the gas... bitaw ng clutch...
#2) Last year I parked my diesel pick-up in a supermarket basement parking, it was raining heavily, as I alighted, you know driving my pick-up van up the runway...inclined eh, the pick-up couldnt go further up. In short, umatras ang sasakyan na pababa...
Luckily, there was no car behind me...if not, wreck talaga.
Thank God, hindi nangyari eto. Well, after 3 tries, I was able to drive my pick-up way up the runway.
...Umakyat ang pick-up when I pressed the clutch halfway, hindi naka Full depressed, mga kalahati lang...Naka-akyat na yung pick-up.
Did I do the correct way? How do you drive your car?
----i drive my car almost the same way as urs... pero pag nasa momentum na yung car mo, bitawan mo na yung clutch...
#3) 3rdly, lets say your driving up to the parking runway of SM Megamall, it's a long curve drive di ba...How do you used the clutch and gas pedal and gear shift?
--- car in 1st gear, tapos steer na lang... pag meron kang kasulubong.. break ng konti, clutch.. then timpla ulet...
#4) eh kung pababa na, lets say, pababa ka na sa runway, what do you used to go down...clutch and brake lang ba?
--- pag pababa.. depende... either in 2nd or 1st ako... depende kung may makakasalubong ako... syempre nakabitaw ang clutch. that way.. ur engine controls the speed, and u still have control of the car, as opposed to clutching it.... para kang naka neutral den non.
#5) Kung pababa ka sa isang slippery road, what gear shift is safe? and how do you apply clutch and brake?
--- same as in #4
#6) Lastly, if you are running so fast, lets say, naka 120 ka sa speedometer...then stop light na, within 10 meters ahead...what do you do to properly stop your car? as in from 5th gear...oaano mo gagawin...at paano ka mag-preno?
- Jan 2003
- 611
November 1st, 2003 08:21 PM #22Originally posted by mk
pag pababa naman. stay at neutral and brake lang ang apakin...
November 1st, 2003 10:12 PM #23Originally posted by sHoCkAbSoRbEr
hindi kaya brakes mo naman ang masunog dito?
November 1st, 2003 11:36 PM #24
I usually give it enough revs so that I can take the incline in 1st gear with the clutch pedal fully released. Then I just cruise in that gear all the way up. Reducing my throttle to avoid overrevving the engine. If I'm feeling a bit adventurous, I sometimes shift into second the moment my engine is almost at redline.
You are taking the slope with your revs too low. That's can cause your engine to lug and even stop (mamamatayan ka ng makina). Climbing with the clutch pedal depressed halfway is a sure fire way to fry your clutch. This is one great example of clutch driving. Have you always done this? Maybe your clutch is already fried and worn down by this time.
I usually just stay in first. It will climb slowly but surely. The curve has nothing to do with it. Just maintain your revs and keep your foot off the clutch and your vehicle can take this ramp. Again, if I'm a bit enthusiastic about my driving, I can shift into second gear even halfway up (sobrang bilis ng shifting, release throttle and step on clutch to shift tapos bitaw din agad sa clutch and back to throttle).
I usually engine brake. I just keep it in first and keep my foot off all the pedals and it will creep down by itself. Sometimes you may need to put some throttle because the engine brake is very powerful will really slow you down to a crawl.
That would depend on the road. But you should always try and stay in gear as much as possible. Suddenly shifting into a lower gear may cause you to lose traction. Shifting into too high a gear may cause you to go faster that you may need your brakes (which adds to your risk of skidding). Just follow the recommended gear for the speed you intend to drive on the road (it is in your owner's manual).
First off, I don't think I'd recommend driving at 120kph with the stoplight within 10 meters of you. The stoplight is placed high so that you can see it from beyond ten meters. That said, I would always let go of the throttle and step on the brake before finally stepping on the clutch. I usually step on the clutch when I feel that my engine is about to die.
Just think of the clutch as a device to prevent your engine from dying. You only use it to keep your engine running during launches, shifts and stops.
- Oct 2003
- 34
November 2nd, 2003 12:33 AM #25always remove your feet from the clutch pedal when the car is in motion para ma iwasan mo yung pag half clutch yan kase ang madaling maka ubos ng clutch lining (tumatakbo yung car and at the same time half engage yung clutch.
November 2nd, 2003 12:38 AM #26
basta umandar na car mo kahit 10 or 15 kph lang pwede mo na bitawan yung clutch (on a flat surface).
November 2nd, 2003 09:53 AM #27
teka..ako kasi madalas tanggal ko talga clutch bago brake. since ive read this thread a few days ago, sinubukan ko kahapon mag engine brake un pababa from tagaytay haha ayaw ko un feeling kasi tumataas masyado un rpm, i mean around 3k -3500.. i guess siguro medyo mabilis kasi ako 4th gear to 3rd then pag pasok mo sa 2nd ayan aangat..then dahan dahan ako brake. is it perfectly ok?
ndi naman ata ako clutch driver except kung incline na traffic d ata maiiwasan yun.. feeling ko sinusunog ko tlaga sya minsan hehe
November 2nd, 2003 10:27 AM #28
pissword, a good technique wud be learning the heel and toe downshift. its footplay pressing the gas and break at the same time.. slowing down ur car, keeping rpm high, left foot presses clutch, downshift, all of that simultaneous. u wud be driving like a race car driver :D
November 2nd, 2003 12:56 PM #29
pissword,
Masyado ka mabilis. Anyways, gasoline naman ang sasakyan mo, malayo pa ang 3,000 rpm sa redline. Sometimes when I engine brake, 3,000 rpm din ako. Pero keep in mind na ang redline ng makina ko is 4,500 rpm. Huwag din masyadong mababa ang gear. Nasa manual naman ang recommended gear for the specific speeds you want to run.
Saka kapag naka-engine brake ka, don't forget na alalayan ng wheel brakes. They are there to complement each other. Huwag ka lang aasa sa isa.
November 2nd, 2003 04:19 PM #30
shockabsorber,
hindi naman masusunog yung brakes kung maikli lang naman yung decline, as in mall parking buildings and short hills. kukulo yung brake fluid at magfa-fade yung preno pag todo preno sa netural ka pababa ng baguio or tagaytay or something hehe
ang galing talaga ni boss otep
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
