--- most of the time... pag 10 meters na... binibilisan ko pa lalo para makaabot ako hehehe. kung nakikita mong yellow na... its safe that u slow down ur car... ako ginagawa ko.. dinadownshift ko (engine break) tapos may konting apak sa brakes.. tapos pag mabagal na... clutch... then brake.Originally posted by Paulo
[B]furthermore, here are my concerns on using the clutch...
#1) Let's say, your car is parked at the basement, for example, in Robinson Galleria basement parking...
As soon as you pay your parking fee....you are faced with a Long Deep inclined road way up...
If your driving your car, what do you do?
---coming from full stop, naka hand break... timplahin ko ng konti yung clutch.. para umusog ng konti. tapos bitaw ng handbreak... press on the gas... bitaw ng clutch...
#2) Last year I parked my diesel pick-up in a supermarket basement parking, it was raining heavily, as I alighted, you know driving my pick-up van up the runway...inclined eh, the pick-up couldnt go further up. In short, umatras ang sasakyan na pababa...
Luckily, there was no car behind me...if not, wreck talaga.
Thank God, hindi nangyari eto. Well, after 3 tries, I was able to drive my pick-up way up the runway.
...Umakyat ang pick-up when I pressed the clutch halfway, hindi naka Full depressed, mga kalahati lang...Naka-akyat na yung pick-up.
Did I do the correct way? How do you drive your car?
----i drive my car almost the same way as urs... pero pag nasa momentum na yung car mo, bitawan mo na yung clutch...
#3) 3rdly, lets say your driving up to the parking runway of SM Megamall, it's a long curve drive di ba...How do you used the clutch and gas pedal and gear shift?
--- car in 1st gear, tapos steer na lang... pag meron kang kasulubong.. break ng konti, clutch.. then timpla ulet...
#4) eh kung pababa na, lets say, pababa ka na sa runway, what do you used to go down...clutch and brake lang ba?
--- pag pababa.. depende... either in 2nd or 1st ako... depende kung may makakasalubong ako... syempre nakabitaw ang clutch. that way.. ur engine controls the speed, and u still have control of the car, as opposed to clutching it.... para kang naka neutral den non.
#5) Kung pababa ka sa isang slippery road, what gear shift is safe? and how do you apply clutch and brake?
--- same as in #4
#6) Lastly, if you are running so fast, lets say, naka 120 ka sa speedometer...then stop light na, within 10 meters ahead...what do you do to properly stop your car? as in from 5th gear...oaano mo gagawin...at paano ka mag-preno?
