Page 25 of 37 FirstFirst ... 1521222324252627282935 ... LastLast
Results 241 to 250 of 370
    #241
    Baka meron sa Toyorama or other sellers of Toyota parts bro.
    1000+km na lang pala due na rin yung pickup for atf change. Has anyone seen any Castrol Transmax Multivehicle ATF? The hardware stores and auto supplies I frequent don't have stocks anymore.
    So its totally different pala from T-IV
    Sent from my LG-H818 using Tapatalk
    toyota ws "world standard". used on 6sp and 8sp new camry.. its low viscosity. mag1 and mitasu have toyota-ws and if you check it also gets dex vi and mercon lv certs
    Apr 2012
    #243
    Yung world standard okay pala yon. Heheh
    Mine is Vios 1.5G
    Mar 2005
    #244
    Hirap na nga din mag hanap sa mga auto supply and sa ace. Used 12 liters of Mitasu atf on my 09 Santa Fe. IMO, much better na ATF yung Mitasu vs Transmax in my case. Nawala na yung shift shock when downshifting from 4th to 3rd pag inclined. Dati kasi kahit bagong palit ng Transmax meron pa din. Now sa Mitasu about 800kms na natakbo ko nawala na talaga shift shock.
    Also medyo overpriced mga labor charges ng ibang shops for dialysis. Most shops ranges sa Congressional/Mindanao ave area charges 1.2k to 1.5k. Sa Exalta banawe 600 lang labor.
    #245
    Quote Originally Posted by jmpet626 View Post
    Thanks sir. I use their coolant. Didn't realize they also had ATF. Will probably go the dialysis route this time since the last ATF change was the drop pan method.
    Jul 2016
    #246
    Re post ko lng po. I just need you inputs mga master:
    Good morning mga sir! I just have an inquiry regarding changing ATF. I want to completely change the fluid inside my tranny. I asked a mechanic ng friend ko and sabi niya na no need na daw for a dialysis. Ibaba lng daw oil pan at linisan then refill. Question is pag drop oil pan lang diba hindi natatangal lahat ng fluid lalo na yung nasa Torque Converter? And besides ang alam ko advisable lang eto for manual tranny which is drain and refill (correct me if I'm wrong). Previously manual car ko but now ng palit na ako ng automatic. Really confused. Ano ba mas maganda for a complete change in ATF. Worried na din kasi ako dahil parang may burnt smell na ung fluid the last time I checked. BTW, ride is Mitsu Lancer 98 GLXI AT with InvecsII/sports mode transmission. Really appreciate all feedback and comments. post lang mga sir. maraming salamat and more power sa forum na eto.
    drop the pan.. change the transmission filter if meron
    ito atf "dialysis ang presyo lang dapat 600 ang labor.....
    Pag siningil kayo ng 1,500 eh bolahana na yun.
    Tapos wag kayo papayag na idillute ng other atf ah.... kasi yung mga nagtitipid eh gagamit muna for flushing ng cheap whiz brand atf.
    Example 8 liters capacity
    magpapa dialysis 12 to 16 liters gagamtin.... yung mga unang buhos eh yan yun cheap atf para daw maituloak palabas tapos the rest yung talagang atf na.... mali yan.
    Kaya hindi ako advice ng dialysis....nangkakwarta lang para madami ka bilhin na atf.... mas ok na yung drain and refil lang....
    Jul 2016
    #249
    Salamat sir stock engine. Will this remove the burnt smell? sorry medyo OC hehehe.
    Feb 2015
    #250
    Pano mo po masabi kung need ng dialysis or not.
    Casa advised me na need ko daw dialysis. 16 ltrs need for that.
    Di nmm na stock kotse ko. MT trans. Mix hiway and city driving. 32.5k km odo reading in 3 yrs. No issues so far. Tia.
    Sent from my SM-G532G using Tsikot Forums mobile app
Changing ATF Fluid completely (DIALYSIS PROCESS)
