Page 24 of 37 FirstFirst ... 1420212223242526272834 ... LastLast
Results 231 to 240 of 370
    #231
    Used this for my vios and innova. no problem. 1st change on vios * 120K Km; Innova * 40K Km; both runs smooth as new, now vios *130K; and innova * 78K, (innova is due have another ATF change on 80K) any other suggestion to use? ATF Type-IV.
    Personally, I don't trust Mitasu. It's not even made in Japan (Russian-made). Then there's these text about it being "Manufactured by an ISO 9001:2008 certified company for Mitasu Oil....".
    Then there's also its claim that this same oil can be used in both traditional A/T and CVT... what a load of c!*p!
    It also uses the word "Suitable" when talking about compatibility with different transmissions. Anyway, before you pour that thing into "the most complex piece of machinery in your vehicle" (the A/T), watch the following video.
    Transmission Fluid Facts - YouTube
    Jan 2009
    #232
    Quote Originally Posted by kapitan88 View Post
    Toyota ATF Type-IV, for starters.
    I've always been a stickler for using the correct Type OEM ATF. You just can't go wrong. It removes the guesswork and all of the 'what-ifs'.
    On the other hand, using a universal ATF leaves a level of uncertainty (which varies from one ATF brand to another) whether if it will hurt your A/T or not. I'm a betting man of sorts but I don't like to gamble with something as expensive-to-repair-or-replace as an A/T.
    Aug 2004
    #233
    Type-IV even when new is dark, malapot and smells evil compared to the common red ATF. It was one of the first things I checked when I got my Vios new 6 years ago. I wrestled with a balky Lancer transmission before that and that taught me to use the correct fluids even if they're expensive.
    #234
    call me picky but i always use oem tranny juices. i don't mind saving and ponying up for the cost just as long as i'm assured stuff like that won't lead to more head aches
    btt: i did dialysis on our rig 2 years ago and i had to buy 15 liters. this year i only drained and refilled the atf since i also included the replacement of the atf filter.
    #235
    where did you have this done? Casa? or outside na?
    #236
    ^ outside. i didn't bother to finish the dealer's warranty
    when you look into the abyss, the abyss looks into you
    #237
    Same here. We've already had A/T issues before and they car just doesnt feel the same after so i really also subscribe to using the OEM fluid to reduce possible issues. You can always purchase them at a dealer or OEM auto supply then have your suking tindahan do the work.
    Apr 2012
    #238
    Any Vios users here? Mine requires Toyota type WS
    Sent from my LG-H818 using Tapatalk
    dexron vi or mercon lv...not official but theyre almost the same...
    Apr 2012
    #240
    So its totally different pala from T-IV
Changing ATF Fluid completely (DIALYSIS PROCESS)
