Results 231 to 240 of 370
August 9th, 2017 09:41 AM #231
August 9th, 2017 10:15 AM #232
Toyota ATF Type-IV, for starters.
I've always been a stickler for using the correct Type OEM ATF. You just can't go wrong. It removes the guesswork and all of the 'what-ifs'.
On the other hand, using a universal ATF leaves a level of uncertainty (which varies from one ATF brand to another) whether if it will hurt your A/T or not. I'm a betting man of sorts but I don't like to gamble with something as expensive-to-repair-or-replace as an A/T.
August 9th, 2017 10:32 AM #233
Type-IV even when new is dark, malapot and smells evil compared to the common red ATF. It was one of the first things I checked when I got my Vios new 6 years ago. I wrestled with a balky Lancer transmission before that and that taught me to use the correct fluids even if they're expensive.
August 9th, 2017 10:34 AM #234
call me picky but i always use oem tranny juices. i don't mind saving and ponying up for the cost just as long as i'm assured stuff like that won't lead to more head aches
btt: i did dialysis on our rig 2 years ago and i had to buy 15 liters.this year i only drained and refilled the atf since i also included the replacement of the atf filter.
August 9th, 2017 02:58 PM #235
August 9th, 2017 04:24 PM #236
^ outside. i didn't bother to finish the dealer's warranty
when you look into the abyss, the abyss looks into you
August 9th, 2017 05:28 PM #237
Same here. We've already had A/T issues before and they car just doesnt feel the same after so i really also subscribe to using the OEM fluid to reduce possible issues. You can always purchase them at a dealer or OEM auto supply then have your suking tindahan do the work.
- Apr 2012
- 3,469
August 9th, 2017 07:30 PM #238Any Vios users here? Mine requires Toyota type WS
Sent from my LG-H818 using Tapatalk
August 9th, 2017 07:49 PM #239
dexron vi or mercon lv...not official but theyre almost the same...
- Apr 2012
- 3,469
August 9th, 2017 08:45 PM #240
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
