Page 16 of 37 FirstFirst ... 612131415161718192026 ... LastLast
Results 151 to 160 of 370
    #151
    ^ na-check mo ba sa diy hardware sa starmall iyong castrol transmax? meron kasi doon pero not sure kung madami stock
    i hope ok na accord mo bro even though medyo mapili talaga honda tranny. balitaan mo na lang kami
    Aug 2014
    #152
    Yes, dun ako nakakita ng apat lang na 1L bottles. Nag tawag sila sa ibang branches, wala daw stock. Kung mag-order naman sa supplier, aantayin pa ng 1 week.
    #153
    ^ ah ok. medyo mahirap din ata mag-hanap niyan nowadays. dami na din kasi gumagamit ata niyan
    Sep 2013
    #154
    Sa pagkakaalam ko lahat ng montero automatic eh atf sp3 ang required fluid.
    Ang castrol transmax wala ako mabasa sp3
    #155
    Quote Originally Posted by chookchakchenes View Post
    Meron sir, diaqueen 3 compatible ang castrol transmax. Ito oh.
    Sep 2013
    #156
    Ayun nasa gitna pala nakasulat sp3 hindi ko na napansin. Kung ganun maganda magstock nyan castrol transmax kasi pati honda required atf eh compatible.
    Dec 2009
    #157
    kung DIAQUEEN SP3 dapat ma meet yan nang atf. either universal o specific.
    maselan ang mga INVECS II sa atf.
    pag dexron III o dexron IV nilagay mo in 3 years time tatagas at upod na clutches at rings sa loob.
    #158
    Quote Originally Posted by miko101130 View Post
    makes me wonder tuloy kung ano mangyayari pag mahaluan ng konti ang atf sa mga invecs ii trannies
    Dec 2009
    #159
    kung konti lang sir, hindi makaka apekto, wag lang almost all fluid...
    matagal naman masira pag mali ang specs ng fluid hindi agad mapapansin. pero it will fail eventually.
    first symptoms is slippage, less power, hesitation in changing gears especially on downshift...
    #160
    ATF Fluid...
    Automatic Transmission Fluid... Fluid!
    dapat AT Fluid lang...
    but once it gets into the index of the vernacular, it's almost impossible to change.
Changing ATF Fluid completely (DIALYSIS PROCESS)
