Saan po meron AT dialysis down south? Imus or bacoor area
good day,
paano malalaman yun ATF type ng honda civic and ilan litres kelangan for dialysis? sorry, tried backreading, hindi ko mahanap yun sagot. thanks!
^^^nakasulat sa manual mo.
Kung ilan liters sa dialysis, depende sa dumi ng atf mo. Pero imho, kaya ng mga 12 to 15 liters.
Posted via Tsikot Mobile App
Good evening, can't find ATF for my Grand Starex.
Manual says Apolloil Red-1 ATF - wala akong mahanapan dito.
Ayoko kasi magpa dialysis sa casa, pwede ba dexron VI na ATF sa akin? Sabi ngkilala ko sa casa daw kasi Dexron IV daw equivalent ng ATF.
tried this last week. sobrang dumi ng atf ko used 8L to flush it our then 4L to refill. mas maganda ngaun shifting at medyo tumipid sa diesel sonsumption.
had this done yesterday on our suv. used up 13 liters all in all in the process. next time dapat siguro mga 15-16 liters para completely sterile na uli iyong loob ng tranny![]()
Ilan liters naman po ang magagamit if hindi mag pa dialysis? Montero 4x2 non vgt at.
Sent from my iPod touch using Tapatalk
Had mine drain, dialysis process last year, ngayon probably later part of the year, papalit ko yun filter
Should I Have My Transmission Flushed
AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - Should I Have My Transmission Flushed
Automatic transmissions benefit from proper service. Unfortunately, many places push a highly profitable up-sell instead. The transmission flush does the vehicle little good and may cause harm.
With a proper transmission service, the vehicle is first test-driven. Next the transmission is inspected for leaks and external problems. Most transmissions have a removable pan and filter. On these units, the fluid is drained. The pan is removed, and the filter is replaced. Next the valve-body bolt torque is checked, and the transmission is reassembled, filled with the proper fluid and again test-driven.
Flushing a transmission is simply a matter of removing the cooler lines with the engine running. Fluid runs out and more is added. When a set amount has been added, the lines are reinstalled. No inspection of internal components are undertaken and what is more important; the filter is not addressed.
Transmission flushing is very popular because it is very profitable.
A low-skilled technician can hook up the flush machine and do something else, while the transmission is being flushed. No inventory of filters or pan gaskets are necessary, and a universal fluid may be used, instead of the vehicle specific fluid.
Transmission failure is many times caused by slippage. Slippage is often caused by low pressure, such as from a restricted filter. The transmission flush does not replace the filter and may stir up debris that further restricts it. Transmission fluid causes very few problems, unless improper fluid is used.
Fluid-color is often used to sell a transmission flush. This is very misleading, as fluid color does not show the fluid condition. Transmission fluid varies widely in color, even when new. Darkening of the fluid over time is perfectly normal.
Transmission fluid color is NOT an indication of a need for service.
The exception would be transmission fluid that is black and burned. This shows a problem has already occurred within the transmission. With burnt fluid, it is too late for a service and repair will be needed.
Proponents of transmission flushing often claim 100% of the fluid is replaced
This is untrue for several reasons. When the engine is running and the transmission is in park, only a part of the fluid is circulated. A good deal of fluid simply flows from the pump back to the pan, through the pressure relief valve. Several components in the pressure circuit do not receive flow at all.
The flush adds new fluid to a circulating volume of old fluid
When continually diluting old fluid by adding fresh fluid, a good deal of the new fluid is also removed. This unused fluid goes into the waste along with the portion of old fluid removed. Perhaps up to 50% of the fluid flushed through the transmission may go to waste. also removed. This unused fluid goes into the waste along with the portion of old fluid removed. Perhaps up to 50% of the fluid flushed through the transmission may go to waste.
Transmission flushing will NOT clean the transmission
The transmission pump circulates fluid during the flush. This is no different from the normal pump operation. Any debris in the pan or transmission case would have to pass through the transmission filter to reach the pump. If this were possible, the filter would become even more restricted.
GM states their transmissions are NOT to be flushed
In the technical service bulletin 04-06-01-029E, GM warns dealerships against several flushing procedures. In regard to transmissions, GM has issued the following statement:
"The use of external transmission fluid exchange or flush machines is NOT recommended for the automatic or manual transmission. Use of external machines to replace the fluid may affect the operation or durability of the transmission. Transmission fluid should only be replaced by draining and refilling following directions in SI. Refer to Automatic/Manual Transmission Fluid and Filter Replacement."
ahaha... kaya pala GM nag publish...
malamang hindi malilinis transmission, eh ATF lang naman ang pinapalitan.
kung gusto malinis transmission itself kailangan buksan mo yun. at linisin from the inside.
ayaw nila palitan ng consumer ang atf fluid so that after the warranty expires papunta ka na sa transmission failure...
transmission fluid is also a hydraulic fluid therefore it must be replaced because it gets depleted and oxidized.
self serving bulletin from GM.
This Toyota declaration na lubed for life yung mga auto tranny nila is pure BS.
^the web article was written by AGCO Automotive Repair Service. see link above. the service bulletin from GM was just part of the article.
wala sinabi ang GM na wag magpalit ng ATF. ang sabi ni GM wag gumamit ng external transmission fluid exchange or flush machines or what we call "Dialysis process". replace ATF daw by draining and refilling, following procedure in their SI "Automatic/Manual Transmission Fluid and Filter Replacement".
Kaya normal na nasisira sa GMC gear ng 4L60, 4L80 mga switch sol o kaya mga built in TCM nila gaya ng 6L80 6T40 6T70
Tsikot Mobile App
