hi plano ko sana magpa dialysis sa exalta ngayon, tanong ko lang po sana kung maayos kaya yung jerk or thud pagpasok ng second gear?
may nakaexperience na ba sainyo nito?
nissan exalta grandeur po pala unit ko.
thanks!
thanks!
hey guys ,
ano ba contact number ng customers cradle?
sa cavite area any idea kung meron na?
checked Servitek in Dasma , ayaw nila yun magdala ka gusto yung sa kanila ka na bumili.lapit na mag70k yun Sta Fe namin e
^pwede basta CVT fluid din ang gagamitin during dialysis process.
mga fogi ask ko lang po sana anong rating at grade po ang kailangan para sa Fortuner 4x2 AT G
bukas ko na po kasi balak magpa change ATF sa kanya...
1st time ko po kasi wala kasi ako idea please help...
Toyota currently uses 2 types of ATF: Type T-IV and WS. use whatever is indicated for your model.
"Using ATF other than what Toyota recommends may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimately damage the automatic transmission of your vehicle."
i believe ganito ang ginagawa ng iba. example if the owner's manual calls for Dexron III ATF, they will use a cheaper Dexron III ATF or equivalent for flushing, and then use premium Dexron III ATF for refilling. now in your case, you may use a Type T-IV equivalent ATF for flushing, and then use genuine Toyota Type T-IV ATF for refilling.
thank you very much for your time and effort sir
napaka laki ng tulong mo saking first time mag palit ng atf haha!
nagawa ko na kanina naka 7 bottles ako for flushing then 4 bottles from casa na T-IV
thank you again so much sir sana lahat dito sa tsikot kagaya nyo...
God Bless
Mga Sirs, quick query lang.
I have my 2007 Santa Fe's ATF changed last week. It is now at 100,000kms.
Supposed to be eh sa 120,000kms pa. Nawala sa isip ko kaya pinabayaan ko na lang din.
Anyway, may nagsabi sa akin na ang required ATF ng SF is SP 3 pero ang nailagay sa Shell Gas Station is Spirax S1 (not Sp 3 spec).
Do I need to worry? Wala pa naman akong nararamdaman na kakaiba after the ATF change.
mitsubishi spec ATF is also being used by hyundai, SP III
model specific yan sir... the transmission requires specific slippage and traction.
do not use regular dexron III to SP III vehicles,
initially wala ka ma-fefeel but eventually it will cause damage on the rings and other components that would eventually degrade the transmission and mostly likely destroy it.
personal experience ko with SPII/SPIII transmission....
mura lang naman ATF comapred to whole transmission.
a good quality SPIII rated ATF will require an average of 60,000-90,000 kms before change.
Better palitan nyo yung ATF niyo sir to be sure. Pa dialysis kayo para ma drain lahat and use Castrol Transmax Multi Vehicle na ATF. Rated for SPII ng Hyundai at Kia. Eto gamit ko currently sa Montero at sa 09 SF ko with 80,000kms.
Ok. Maraming salamat mga bossing.
This week papalitan ko ng SP3 yong ATF ko.
Actually every 40,000kms ang palitan ng ATF ng Santa Fe. Nag-OA lang kasi ako na palitan lahat ng fluids on my 100,000kms.
Ang positive side lang eh parang pinang-flush ko lang yong Spirax ng Shell then palitan ko na ng SP3 this week.
Wala pa naman Transmission problem or other problems yong SF so far on its 100,000kms.
I think ok na muna ako sa Drain and Refill. Yon lang din ang ginawa ni Shell last week.
Now lang ako nagpa PMS sa labas. From 1,000 to 95,000 kms, sa Casa po naka-maintain si SF.
So, I believe, on my 40,000kms and 80,000kms eh drain and refill lang din ginawa sa Casa (Hyundai Las Pinas)
San makikita ang atf dipstick ng ford everest gen2. 100,000kms na kase tinakbo. Anong atf grade kaya ang kelangan at ilang liters?
