Results 1 to 10 of 370
April 13th, 2011 11:51 AM #1
sirs may alam kayo nagpapalit ng automatic transmission fluid yun "DIALYSIS" style?
kasi po gusto ko mapalitan lahat ng lumang ATF sa kotse ko pati yun nasa Torque converter?
pls post here kung saan yun magaling na mechanic or shop. thanks.
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 13th, 2011 12:04 PM #2If I'm not mistaken, both Speedyfix and Autotechnika does this. I think they use a machine. It can also be done manually. Just be ready to buy around 18 liters of atf
April 13th, 2011 12:07 PM #3
Had mine done at Autotechnika before.... used up 24L of ATF to completely clean the system. Sulit naman.
The amount of ATF needed depends also on how dirty the system is.
April 13th, 2011 02:42 PM #4
wow that's a lot of ATF to flush! thanks a lot guys for the help! punta na lang ako dun!
- Apr 2010
- 38
April 15th, 2011 11:19 PM #6
how about the process of AT dialysis? nakakailan friends na nakapagsabi na maganda daw yung process at hindi magasto kasi normal ATF qty lang kelangan
April 15th, 2011 11:33 PM #7
saan area nyo sir? sa east side meron sa alpha performance along gil fernando ave in marikina
sa quezon city area meron sa fronte ata yun sa banawe/kabignayan st
April 16th, 2011 12:10 AM #8
Yup sa fronte sa banawe meron, dito sa shell station along gov drive malapit GMA Cavite meron
April 16th, 2011 01:00 AM #9
complete atf flushing? shops with ATF transfer machine will be the best place you should go but if you are on a tight budget, you can DIY also...
all you need is a good helper, a funnel and your guts to do it....
- Aug 2003
- 46
April 16th, 2011 09:40 AM #10just did this sa starex AT ko last month, umabot ako ng 2.5k kasama na dito ang 12L of total ATF at labor, mas mura sa EXALTA banawe kaysa sa fronte, sa exalta pwede ikaw magdala ng ATF mo at P600 lang babayaran mo sa machine
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
